zackmd1
I am trying to figure out if PTV clearance with the stock gen 3 pistons will be sufficient with 5.2 heads and predator cams (14mm lift 270 duration). Been looking around and have yet to find anyone document this configuration... Ford performance states that 5.2 heads on a 5.0 will require piston mods but give absolutely no specifics.... Comp cams Gen 3 cams have very similar specs to the predator cams and appear to not require mods or any VCT limitation. Has anyone here seen a 5.2 head/predator cam configuration or have any info?
I currently have a set of Voodoo heads at the machine shop and would like to purchase a stock gen 3 shortblock to bolt them to. The predator cams would be required due to the use of a gen 3 PCM. The FP 5.2 cams are identical to the predator cams but with gen 2 trigger wheels for the cam sensors.
