Viking Shocks - The PP "Bounce" is Gone!
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
Viking told be to use the bump stops BUT to cut off about 1 inch from the factory bump stop to let it have more travel ..This was the old shock not the new updated ones I have now .. Seeing that the rod is longer it might not need to be cut down like the old rod .. Might be a good idea to call them and ask ..
smokinzx14r
ST Petersburg FL
Lee
@beefcake I noticed these didn't come with nuts for the stud mount, Am I supposed to reuse the factory nut? The bag of hardware just had bolts washers and nuts for the bottom mount.
My replacements came right from Viking and had all the nuts ..
Falconeddie
alaska
GTP DIBM Auto 20"
I have the new version on hand awaiting summer before installing them (Live in Alaska). I took a look at the paperwork. It would be nice to have a diagram and a few pictures to go by for a successful installation. I would think Viking would want this newer version to be a success.
WeinerDog
VA, USA
2016 Ruby Red GT/PP
Missing parts, no instructions. Sheesh. Any other shocks that might have these things and work well, too?
zuki_dan
North Carolina
15 Mustang GT Premium M6 TY
I got my new shocks finally installed today.
The new shaft version uses the factory top nut. I also removed the snap ring from the top of the shaft and slid the factory bump stop and dust boot over the viking shock then replaced the snap ring.
I went for a short test drive afterwords they handle much better than the base shocks. I currently have them set 3C/5R based on the suggestions I have seen. I noticed after I installed the lower control arm bearings and toe link bearings those seemed to exaggerate the rear suspension bounce with the factory shocks. I may try to lower the compression setting 1 click and test a little more. The rear suspension compression is definitely more firm but not harsh and the rebound feels about spot on.
Falconeddie
alaska
GTP DIBM Auto 20"
Zuki_dan....thanks for the Viking shock report. Please continue to update your findings as you try different compression and rebound settings if you would please. Is your car lowered or stock height? Thanks so much.
Falconeddie
alaska
GTP DIBM Auto 20"
Sorry, forgot to ask....if your car is lowered, did you have to trim the bump stop? My car is stock and was wondering the bump stop procedure. Thanks much, your the man.
zuki_dan
North Carolina
Yes my car is lowered on BMR performance springs with BMR sways set full soft.
Yes I trimmed my Factory bump stops per the Image in the BMR lowering spring instructions. It shouldn't be required if your not lowering the car. The new version shaft matched the size and thread of the factory shock with an added snap ring on the top edge of the shaft.
zuki_dan
North Carolina
Big question is have you noticed any rattling noises?
On my short test drive last night I could not hear any noise from the back of the car with the new shocks. I even drove it down a bumpy road to see how it handled.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Off to a good start then. Thank you for your input and please keep us updated :)
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
Anyone know when they will have struts for the front?
Jmeo
You said member ;)
Massachusetts
Jaime
I messaged them and they said in the spring.
They have been saying January for the last 6 months lol.
Glad I decided to get the FFRP shocks/struts
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
Lol, I'm ordering the FFRP and BMR handling springs soon.
