UPR Catch Can Noise?
menaecoboost
San antonio
Carlos
ecoboost mustang black PP pack
is this the sound?
my car started making an annoying squeaky noise, it goes away when I unplug any of the hoses on the DVCC. video is attached
ypena02
Massachusetts
2017 Mustang GT
menaecoboost
San antonio
Carlos
Yeah it just started happening after I installed my clean side catch can... Hopefully joe can give me some insight here..I'm going to trace back and double check all the connections again in the meantime .. Sounds like a pressure leak
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
Look at the check valves and make sure they're installed in the right direction.
UPRjoe
750 S. Eastcoast St, Lake Worth Fl. 33460
www.uprproducts.com
Joe
UPR 2015 Ecoboost Mustang
I was thinking the same thing as that sounds more like a check valve or something backwards....
The only time I hear that sound is when something is blocked or the vacuum is trapped from a crossed or blocked line.
That is not a vacuum leak as you can clearly hear the squeaking get higher pitched from the increased vacuum. Then you
can hear the catch can release all the vacuum and make a suction noise when he removes the line.
menaecoboost
San antonio
Carlos
Yeah I've had a DVCC on for about 4K miles and both arrows on the check valves are facing away from the catch can.
menaecoboost
San antonio
Carlos
All my noises and squealing went away when I installed the revised pcv oil separator.... So I'm guessing there was too much pressure or something.
kenbidwell
Tampa
Ken
2015 Mustang GT, 2020 F250 Tremor, 2008 Pontiac Solstice GXP(wifes car)
I'm having this same issue with my catch cans on my GT that I recently installed the Edelbrock supercharger. Sound more from the passenger side. It is intermittent. Does it sometimes and doesn't others. It is really embarrassing in traffic when it starts, sounds bad outside the car. I have checked and the catch cans are doing the job though. I have also checked the install to make sure the flow is correct. Any updates would be appreciated..
