Upgrading to Quality Audio from Base System
horsepower addiction
Arizona
Nate
s550
You can use a sync3 no problem. You can add speakers, amps, subs with any infotainment system. Super easy and the sky’s the limit. If you use a aftermarket system you need a system that can integrate and extra parts to keep all your factory functions. Ether way is not a problem
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Yes, it's from Katzkin. It came out better than I'd hoped. Only problem is that I don't think upholsterer put the door panels back correctly. The handle flexes away from both doors now. I don't remember them doing that before. I'm going to take one apart this weekend and have a look to see if its something simple.
There’s a 10mm bolt right behind the grab handle. If they didn’t reinstall that it will certainly flex. You have to remove the window switch trim panel to get to it.
samiamdamustangman
Gulfport
Samuel
2015 mustang
I recommend Kenwood also.
Love the jl audio mids and highs.
I have a skar and alpine amp.
A star and pbx 12" subs.
I mixed it up so the subs will hit more frequencies.
There are several good brands but ill upgrade the skar to punch soon.
Becarefully not to get bigger than a 12" sub and test fit the box.
My 2 12" box math is so perfect I can't have 2 12"s in one box.
