Upgrading to a performance pack cluster guages
michail71
2018 GT 401a A10
I've seen a retrofit of the Performance pack IC done on an ecoboost. Does anyone know if this will work on a 2018 with a digital cluster? It looked to mostly be plug and play.
In the retrofit I saw the guy said he needed to get a sensor for the oil pressure but I'm wondering if that would be needed if the car already has the digital IC (given it can show the virtual oil pressure guage).
The turbo gauges seem to be easy to find but not as much with the vacuum only gauges. Also, I can't seem to find the trim panel.
michail71
2018 GT 401a A10
Thanks, I think that one pertains to swapping to the digital IC. I already have that. I'm thinking about adding the performance cluster (oil pressure/vacuum) that goes between the AC vents.
michail71
2018 GT 401a A10
Apparently the GT owners swap the gauge assembly out for the ecoboost version when they add in forced induction. Perhaps I can pickup the vacuum gauge from someone.
I think this is definitely on my short list. You can never have too many gauges.
michail71
2018 GT 401a A10
Anyone know about the oil pressure signal? Given I'm showing it now in the digital IC I'd think it should work??
There are full panel/cluster assemblies on ebay for $450. The gauges on their own go for around $250.
