2018 Digital Gauge Cluster
Sasuketr
Chicago,IL
2015 Ingot Silver GTPP
Hey guys. I ve disassembled my current cars dash board and even took the gauge cluster out so many times. Looking at the My2018 interior pictures, the housing for the digital cluster seems to be the same. If the cluster is not vin locked, my guess is you can purchase this from Ford Parts website for 300 to 400 dollar range and fit it inside the housing. For the premium models with mycolor option, this seems to be a possibility. The steering wheel buttons for the mycolor and menu options seem to be the same besides the extra mustang button.What do you guys think?
Nuked
Morgantown, WV
2016 Triple Yellow GTPP w/Recaros
I would bet it is a good chunk of coin more than 300-400, probably closer to 800-1000
Being that it is an option, it will most likely fit and plug in physically. Question will be if the BCM needs swapped as well, which it probably does.
18psi
of boost
Best Coast
I'd be surprised if they weren't vin-locked. At minimum I think you'd need to re-program it to the car and immobilizer.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
This. You'd need to reprogram the cluster for your car, and there's a good chance a lot of it is not backwards compatible with the older PCM and BCM, and I'm not sure about the Chassis/ABS module.
whalesalad
Costa Mesa, CA
2016 GT PP
I'm guessing it will be possible. It might not be easy, but I think it will be possible.
I say this primarily because:
  • It's an option, and cost-wise it makes more sense for Ford to have everything that hooks up to the cluster be identical across all models
  • The outside of the housing does look similar, and probably is.
  • Even if there is a software reconfiguration required, I can't forsee it being completely impossible.
  • The steering wheel controls appear identical on newer models. It wouldn't make sense for Ford to completely change the programming interface to interact with the new display.
Long story short, it makes the most economical sense for Ford to change as little as possible between model years because of all the tooling that exists, third parties that are already on the line to manufacture components, QA that has already been performed... etc...
My gut tells me this is a plug n' play. If I'm right, I'll be one of the first to order one. It's so much more radical than the current display.
El_Centenario
5L V8PWR
Apple Valley , CA
David
'15 Mustang GT Triple Yellow
I was thinking the same thing when I saw the gauge cluster. I would also like to change it on my car if it were plug and play. If it needs programming, hopefully [MENTION=20927]OEMRadio[/MENTION] can take a look and see if it can be possible to program it and get it to work with our cars.
Sasuketr
Chicago,IL
Thats what i m thinking too, plug and play, especially for the current premium owners. Now the heated steering wheel on the other hand, i can live without!
kz
West Chester, OH
Mustangs & F150
The key question is - why ???
Phoenix
Instagram: PhoenixNFA
Central Texas
2016 GT350 Tech AvGrey/Black Stripes
Notes
Moustang
Belgium
BLACK S550 EB/AT/PP/EU
Not such a fan of the digital speedo, but I do wonder what type of parts might fit the 15-17... could become interesting :thumbsup:
zuki_dan
North Carolina
15 Mustang GT Premium M6 TY
I would be interested in the swap but I am sure it would need to be programmed for mileage and VIN then hopefully everything else would be backwards compatible. I like the track mode pic that turns it to a big tach bar graph.
Silver_Bullet_S550
Cookeville, TN
Rashad
2016 Ingot Silver GT Premium
it is possible, and the cluster is 2200
