MACHtobers Very Own
- Jun 17, 2021
- Hampton Roads, Virginia
- 2022 Mustang MACH 1
I am writing because I am at a crossroads on my suspension set up. I feel like I am getting twitch, float, and wheel hop all in various conditions. Certain types of roads/scenarios create:
-a twitchy/nervous side to side action that makes me feel like i'm wiggling back n forth in my seat.
-a floaty front end that unsettles the car and it feels like the car is rocking back n forth/front to back.
-a floaty up n down where the whole car pancakes up and down
-when I gun in a straight line it feels like the rear is planted but the front is not. It doesn't lift up but doesn't feel planted
-wheel hop is occurring sometimes usually in a turn which then sometimes really unsettles the car front to back
An afternoon drive can yield a whirlwind of stiff one minute floaty the next driving experience. Sometimes you feel everything and its a good thing and sometimes its not.
Sometimes changing drive modes helps but really degrades my confidence in driving and overall fun. Sometimes Normal is way too soft and sometimes track is way too rough but that will also flip flop.
Thoughts? Car just feels BUSY I know its subjective and overall it's not the end of the world but I was curious if anything glaring stood out to folks. Main usage is weekend warrior/aggressive back road driving with some light cruising here n there.
Car in question:
2022 Mach 1 w/ HP
16000 Miles
6 speed manual
Magneride Equiped
Tires:
PS4's
305/30/19
315/30/19
34PSI on tires
Alignment:
Caster 7.1/ 7.4
Front Camber -1.9/-2
Front Toe -1/16
Rear Camber -1.7/-1.5
Rear Toe 1/8
Current Mods on the car:
Steeda:
X-Pipe
2 point brace
Jacking rails
IRS Subframe supports
IRS subframe bushing support
IRS Subframe alignment
Vertical Links
Adjustable Rear Toe Links
Bumpsteer kit
Diff Bushings
Competition Sway Bars (second softest up front and stiffest in rear)
Billet front sway bar mount
Camber Plates
Adjustable Camber Arms
Sport Progressive Springs
Stainless Steel Brake Lines
front/rear ride height spacers
UPR:
Engine Mounts
Car in question:
2022 Mach 1 w/ HP
16000 Miles
6 speed manual
Magneride Equiped
Tires:
PS4's
305/30/19
315/30/19
34PSI on tires
Alignment:
Caster 7.1/ 7.4
Front Toe -1/16
Rear Toe 1/8
Steeda:
X-Pipe
2 point brace
Jacking rails
Vertical Links
Bumpsteer kit
Diff Bushings
Camber Plates
UPR:
Engine Mounts
