Interesting TSB for the MT82, which shows stock clutch failure that may be related to excessive wheel hop from aggressive launches, and doc calls for Peak Torque Limiter replacement.
Per TSB:
See attached PDF for images and location of the Peak Torque Limiter.
Per TSB:
--Summary
Some 2018-2020 Mustang vehicles equipped with a 5.0L engine and an MT-82 manual transmission may experience a loss of movement and/or difficulty shifting. This may be due to excessive wheel hop which is caused by aggressive acceleration at low speeds while using launch control. To correct the condition, follow the Service Procedure to replace the failed components and replace the peak torque limiter.
