Trunk release
Medsport
Ohio
2016 Guard Premium GT automatic
Hey guys, I have a new issue today. I went to get groceries and filled the trunk up and when I got home I could not get it open! The button under the trunk doesn't work nor the key fob. I had to put the seats down and crawl through to pull the release. Any idea what it could be and would it be covered under the basic warranty?
fmc_smt
Cottonwood , Arizona
If your under base yes there is a tsb for that .
Medsport
Ohio
So that means it is covered then? I'm wondering if its related to my rear camera stopped working about 60 months ago? I was going to let that go as I was planning on trading it in this summer, but decided to look for a newer house first (with a garage for my next new car) and its taking longer than I thought it would to even get my place listed because I've been having trouble finding a decent contractor that wants to work on it anytime soon.
tranceporter
Fort Lauderdale
2019 C7 Grand Sport
This would be covered under the 3 year/36k mile limited warranty.
Medsport
Ohio
Yeah, but I'm over both of those.
fmc_smt
Warranty coverage all depends on how the claim is coded . You need you need to have the vin ran against the causal part number to find out what warranty coverage there is left .
jacknifetoaswan
Charleston, SC
It's an easy fix. I put out a write-up on this about a year or so ago, so search my posts. You simply need to trace the wiring harness on the right side of the trunk and find the broken wires (they'll be right where the trunk and the body meet). Remove the cladding, strip and solder the wires, or use butt connectors, then re-wrap to protect the wires. I soldered a 6" extension into it so that there wouldn't be stretching or other issues.
JR
Medsport
Ohio
I don't have a garage or hardly any tools. My dad may have a soldering gun and he used to be good with cars, but he's getting up there in years.
Here ya go:
https://www.mustang6g.com/forums/threads/backup-camera-not-working.122961/
https://www.mustang6g.com/forums/th...ear-camera-stop-working-heres-the-fix.117245/
The TSB and how to fix is in the above threads.
Most likely the specified wires broke inside the right side (passenger side) trunk wiring harness.
TSB will only cover it if the car is still under the 3/36 Warranty (or maybe if you have a Ford ESP plan that covers electrical). If 3/36 is done and you don’t have an ESP plan, you will have to pay for the repair.
Don’t pay for the repair, it’s an easy fix as outlined in the above thread.
Medsport
Ohio
Thanks for the info. I'll check it when I have more time. But I'm in the process of trying to fix my house up while working FT. I wonder what the dealer would charge (ballpark) to fix it? If it was say around $100 or so, maybe, but much more than that then I'll see if me and my dad can tackle it when I get a chance.
fmc_smt
Actually it is covered under safety restraint warranty 5 yr 60k . I ran my vin the coded base number for the heck of it .
PART NUMBER: 14A005 (WIRING ASY)
REPAIR DATE:08/26/2020
REPAIR DISTANCE:28000 Miles
COUNTRY:USA
STATE:OH
IS COVERED UNDER -SAFETY RESTRAINT
Davesvt2000
Massachusetts
2021 Mach 1
What about the release button on the left side of the steering column, does that work ?
jacknifetoaswan
Charleston, SC
You barely need any tools. Go buy yourself one of these and some red butt connectors, along with some 18 gauge primary wire, and electrical tape or heat shrink tubing. Cut the wires, strip them, crimp on butt connectors, add 6" of primary wire, crimp the ends, wrap with tape or heat shrink.
JR
COUNTRY:USA
STATE:OH
@fmc_smt
That’s interesting to know.
So is it safe to say that some of the vehicle body harnesses are covered under the 5/60 only IF that same harness is tied to a BCM within the vehicle that is also safety related (lights/airbags)?
fmc_smt
@fmc_smt
Depends on the part base number , only way to tell is to run the base number on the parts coverage tool on oasis
