Trunk release button under bumper acting crazy
wanted33
Down South in Dixie
Jim
2018 GT Convertible, 2006 GT Coupe
As stated the trunk release button under the rear bumper is "working/not working" occasionally. All other options to open the trunk are operating properly. Does anyone have any suggestions, or experienced this little problem. I know full well if I take it to the dealer it will work. So if there's something I could easily do, that would be much more gooder than sparring with the Service Writer :) Thank you in advance for any help.
DickR
Raleigh
Is the key fob "with you" vs still in the car when you push the under bumper release button and it doesn't work? What about electronics or lots of keys or other metal in the same pocked as the key fob?
I never had a problem with my 15 or with my current 18.
DropTopBob
Manassas, VA
Bob
2017 EB Conv, Perf Pak, Borla Sport Axleback
My ‘17 behaves same as OP. I’ll have the keys in my pocket yet the bumper button won’t work. Happens about 10% of the time. However, like most things in life I’m fine with 90% success.
wanted33
wanted33
Down South in Dixie
Jim
At least I'm not alone in this boat alone Bob. I think I'll be like you, and take 90% as a win.
Dick, yes sir it's in my pocket all by itself. I'm gonna put a new battery in the FOB just for the heck of it, cheap enough and may help.
DickR
Raleigh
I would be surprised if it is the battery since my 15's were fine for all three years with lots of use. Good luck.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
The exposed wires to the trunk lid get frayed on the 15-16 cars because they’re too short.
Check yours and repair. If you’re under warranty a dealer can fix it for you. Trunk latch issues are not uncommon.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
I believe that button doesn't work if the engine is running.
wanted33
wanted33
Down South in Dixie
Jim
I will check that. Thanks for the tip
VinnAY
Kansas City
18 Camaro 1SS/1LE
Thjis is true, little quirky things start to happen like this, the camera goes intermittently inop, fob won't open the trunk, things like that as it get's worse. Dealer didn't have a good fix for it that I knew of and was a primary reason I unloaded the car 6 months early. AS I left the car the only way to open the trunk was the interior push button. I had to run a rope thru the trunk to the interior emergency release, just in case.
NightmareMoon
My dealer fixed it right up by splicing an extension into the harness. It wasn't their first car with the issue. No problems since then.
You got rid of the car for that?
wanted33
wanted33
Down South in Dixie
Jim
Nightmare, I'm out of town right now, so I can't look at the wiring. But, can you tell me what I'll need to do to check them? IOW, do I need to remove anything to get too them? TIA.
NightmareMoon
Its the expose wire cluster / loom next to the right trunk hinge, you can't miss it. Just look for any signs of fraying, separation, or damage for starters. Its like a 95% chance that this is your problem tho.
I guess its possible that a wire inside could be pulled, I don't know for sure if damage will be visible from the outside. If your car is out of warranty, I'd probably still take it to a decent Ford service department and pay them fix it for you. They'll certainly know what to do.
ElAviator72
Canby, OR
Brent
2016 Ecoboost PP Deep Impact Blue (base 100A car)
That's what the trunk release button on the driver's side bolster is for (left side of steering column) :like:
VinnAY
Kansas City
18 Camaro 1SS/1LE
Well not exactly but long road of many months funkin around with the wiring and all the trunk problems made it an easy choice when Chevy said they'd take the remaining 6 payments on the lease it was a sigh of relief. I had tons of problems with this particular (only) problem that Ford wouldn't/couldn't fix, so...
