Transmission noise?
svtgt350
Markham
gt350
I'm getting a winding in second ?
300 k on the new car
any thoughts, is this part of a breaking issue?
svtgt350
svtgt350
Markham
gt350
yes 300 kilometers
or 180 miles
svtgt350
svtgt350
Markham
gt350
there is an excessive wine in second that I dont hear in other gears
cosmo
Michigan
2005 Mustang GT
It's probably due to the cold weather and the fluid being optimized for high temp track usage. Does it go away after the car is warmed up?
svtgt350
svtgt350
Markham
gt350
thanks cosmo
I'll confirm and be back
however I did have the engine temp up oil 80 c
ambiant outside temp was 8c
cosmo
Michigan
2005 Mustang GT
Hmm... With the oil temp at 80c the trans should be warmed up by then. Best of luck.
arsenalrocks
GTA
2016 GT350
in colder condition, before driving off, I always depress clutch and row the gears from 1-6 then back to 1. see if that helps.
Hack
Minneapolis
Mustang, Challenger
Did this happen from the very first drive or is it new just occurring?
If it just started I would take it to the dealer right away.
If it happened from the beginning it may be a characteristic of the vehicle and how it is built.
65Terdlingua
Kansas City
1965 Mustang
I would take it back either way. The cut on second gear teeth isn't any different than the other 5 so it should not be producing excessive noise. In reverse you'll hear normal gear whine from straight cut gears. My brother had an 11 with excessive noise in second and eventually started to catch on engagement. He took it in and they replaced second along with multiple dog collars. Not suggesting these are the same transmissions obviously, but still should have it looked at.
stanglife
Jeff
1993 Coyote Coupe
That doesn't do anything because the gears are not spinning.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
If you have to listen for it, don't worry about it. If it's a screech where it can be heard over say the radio at a reasonable level, then get it checked out. Honestly, I think you're just making yourself go mad.
I had a very nasty whine coming from my '11 car but it was a brutal whine. Very noticeable, very loud. It was like I had a Kenne Bell on my rear axle. If that's the case, then go get it checked out.
svtgt350
svtgt350
Markham
gt350
took it to the dealer
drove with the technician; he suggested to drive it for a while and let the gears mesh;
if i push the shifter to the drivers side the noise disapears
and yes I have to listen for it with the radio off and in normal mode otherwise I can't hear it ; so maybe im being too picky ?
however i do have the warrenty
I'll revisit the issue in the spring :0
