Transmission fluid leak?
matthewr87
2018 GT350
I noticed some drips on my garage floor. Had a quick peek and it looks like I have transmission fluid leaking from somewhere (based on the red fluid on the bolts). Anyone have a similar issue before?
matthewr87
matthewr87
2018 GT350
I'll try to get the car up on my lift this weekend to have a look. I haven't tracked the car in over a year but it has been quite hot here in general.
matthewr87
matthewr87
2018 GT350
Another picture. Maybe it's leaking from that plug?
matthewr87
matthewr87
2018 GT350
Here is a better image
matthewr87
matthewr87
2018 GT350
Okay so it's either the drain plug or the cooler line fitting
Datalux
SoCal
2016 EcoBoost, Premium, Auto, PP
That's definitely annoying to find on your garage floor. Definitely get it up on that lift and check the cooler lines and the shifter seal—those are pretty notorious for weeping on these cars even when they aren't being pushed hard. If it's not coming from the breather vent like some guys mentioned, it's worth cleaning everything off with some brake cleaner first so you can actually trace where the fresh fluid is tracking from after a quick drive. Good luck, hope it’s just a loose fitting or something simple.
matthewr87
matthewr87
2018 GT350
Thanks! I went underneath the car earlier and it looks like the rear-most transmission cooler line fitting is leaking. See the pictures above. My AC has been dead for a year now so I think I am finally going to have to take this thing to the dealership and make use of my PremiumCare ESP.
matthewr87
matthewr87
2018 GT350
This applies to GT500s, but you may have the same problem.
Hmmm yes looks quite similar. Between this and my AC being out (as well as the rear view camera recall I was hit with) I'm finally taking it to the dealership next week. Might as well use my ESP.
matthewr87
matthewr87
2018 GT350
Welp.....tomorrow my GT350 is going in to the dealership. First time in 7 years. Wish me (and my car) luck please :frown:
wingnutt
@FL410
michael
350R Procharged w/P1X
yes, this… have you done anything to the tranny in regards to draining/filling/servicing?
The Ford tech manual references; the seal and the keeper inside the tranny cooler lines is the only reason I’m asking šŸ˜‰
fun fact…the same wording got me in trouble with Denver Air Traffic Conrtrol šŸ™Š
matthewr87
matthewr87
2018 GT350
:giggle:
I did change the tranny fluid about 10k miles ago. And it hasn't been leaking for that whole time. So I'm leaning toward the transmission cooler fitting. Plus that sits higher anyway and the area up top has tranny fluid residue.
matthewr87
matthewr87
2018 GT350
Interesting development so far. The cracked high pressure AC hose was covered by PremiumCare without issue. The tech is going to replace it, fill the system, and then run the AC to evaluate my compressor whine. That will probably need to be replaced too. But, PremiumCare is pushing back on covering the transmission leak. My ESP contract states that transmission seals are covered. But it also says that transmission coolers are not covered. The tech specifically ordered the seal that plugs the hole in the transmission where the cooler line attaches. So I guess this is a bit of a grey area. My service advisor is going to try to get them to cover it. Let's see what happens.
drought_buster
Michigan
2017 GT350
It appears the black o-ring on the trans cooler line is not fully seated. That fastener needs to be loosen and the o-ring reseated. It may have a bent cooler line bracket and that is why the o-ring is exposed. That is what I see in your photos.
Edit: never mind I immediately went to a reply instead of reading the entire thread. Sounds like it’s already being looked at. Good luck.
