Diff and transmission fluid change
UnhandledException
States
2017 GT350
Is it a good idea to change these? I have 63,000 miles on my transmission fluid and about 30,000 miles on the diff fluid.
Frank.Herbst
Denver, CO
Frank
2019 GT350
Congratulations on the milage.
Fluids have changed so much over the last years. I usually check with the recommended service intervals. If they seem crazy long I might change early.
UnhandledException
States
2017 GT350
Thank you.
The recommended service for transmission is 150,000 miles. I dont see any interval for diff fluid.
NoXiDe
GA
GT350
Service manual
Every 150,000 mi
Change manual transmission fluid.
Change differential fluid.
Replace accessory drive belt(s).
If you feel like doing it earlier, you certainly can.
dpAtlanta
Atlanta, GA
'19 GT350 (#K2503), '17 Cayman, '24 Bronco Badlands 2-door, '26 Ranger Raptor
Okay... I'll bite. Did you change the differential or the differential fluid at 33,000 miles, and if so, why?
Just curious...!
UnhandledException
States
2017 GT350
Just curious...!
Diff pinion seal was leaking and had to be replaced along with half shaft seals, it was flushed as part of that service.
MikeR397
MI
Ford GT350R & Raptor; Ferrari 360, Aston Martin Vantage, Porsche Cayenne GTS, Jaguar XFR
If it’s not tracked, I’d go at least 80% of the miles the manual says. If tracked, I wouldn’t fault you for being more conservative.
UnhandledException
States
2017 GT350
Its not tracked. Almost 60% of the miles is city miles. I ll probably do it around 75,000 mile mark. I did the plugs at 50,000 miles and there was a lot of concerning squeaky noises which made me hold my breath several seconds longer. I dont know what would happen to those plugs in 100,000 miles if I were to listen Ford.
Alain
Northern NJ
Alain
2016 Challenger Hellcat / 2019 350R #413
I'm still baffled that Ford doesn't recommend you change the differential fluid for 150,000 miles !!!
There are gears in there, what makes them different than any other differentials in the sense that they wont release shavings as the gears break in.
Arknsawchuck
Cabot, Arkansas
Chuck
2019 Mustang GT PP2
It certainly won't hurt to change the fluids earlier. I changed both mine at 3000 miles just for peace of mind. I plan on changing them every 30000 miles or so just because its pretty easy to do and doesn't take much fluid in either, (diff. And manual xmsn) so the cost is low. But thats just me.
UnhandledException
States
2017 GT350
I thought the transmission fluid change required you to run through gears and refill while on the lift which is why I avoided doing it
torque124
Torque
MA
Shelby GT350R
It does, but upon lifting her up to refill, level was still there, nothing to refill... So, it' s pretty straight forward.
JAJ
Vancouver BC
2016 GT350 Track Pack
Well, sort of. The instructions say to drain the fluid, refill to the bottom of the fill hole and then run the engine with the clutch engaged to run the fluid pump to push fluid through the cooler and clear out any air that might have gotten into the cooler lines. You can do this with the box in neutral because the pump runs off the input shaft - there's no "through the gears" required like it would be on an automatic.
However, I've probably changed mine a dozen times by now and having run the pump the first couple of times, I've discovered that, as @torque124 said, there's actually no room for more fluid after running the pump, so I don't bother any more.
Of course, the other thing I do is run XT-11-QDC with a shot of XL-18 rather than Mercon LV. Shifts way better.
torque124
Torque
MA
Shelby GT350R
I run the recommended fluid from Amsoil, it is much better than stock one. Especially at cold...
