Transmission Cooling Line Leak
94Gator
Naples, FL
Pete
2017 GT350R
Has anyone experience leaks in the transmission cooling lines? If so, any insight into what might have caused it? 2017 R has only 6500 miles. Tracked 3 days in past 2 months which could likely be the culprit, but wanted any added opinions. Like to know if it's something that is likely to happen regularly.
Tomster
Beware of idiots
Tom
Nope, not a common issue. If you track your R, the oil pressure sensor does come loose. Make that part of your pre-track inspections.
jpsomner
LA
2016 GT350R base, chassis # G0089(GR015), Blk/wht
My car had 10k miles on it when I got it. First track day, ended second session with a rooster tail of white smoke. Cracked transmission line. Replaced it and no problems since. Maybe rocks kicking up into the lines?
Hack
Minneapolis
Mustang, Challenger
I would assume some defect in one of the oil line components or an assembly error as the cause.
When I had my engine oil cooler lines replaced under warranty at a local dealer, they leaked slightly the first time. I think the tech didn't get one of the fittings fully seated.
94Gator
94Gator
Naples, FL
Pete
2017 GT350R
Good thought, Thanks! Lets hope it's a 1 and done issue!
94Gator
94Gator
Naples, FL
Pete
2017 GT350R
Yes the next headache to worry about-whether the techs fix it properly without screwing something else up! Thanks.
gtodoc
California
Wayne
2020 GT350
2020 GT 350 transmission cooler line cracked at retainer area. 7,000 miles street driven only.
oiled the bottom of the car and exhaust.
This was the rear line at the trans connection.
