Traction Control Off combined with Track Mode?
NeverSatisfied
Pittsburgh
2021 GT 6MT Base
I wouldn’t recommend turning anything off until you know when it’s activating, can activate it at will, and it’s intervening particularly when rolling into the skinny pedal post apex.
this feature isn’t subtle—you can tell when it’s doing its thing
GTP
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
I see that when I switch to Track Mode the yellow traction off light comes on in the display. So the basic TC is automatically disabled.
Long holding the traction toggle disables Advance Trac. That is what I have yet to try on track.
NavsENG
San jose
2018 GT , 66 Track coupe, 66 street car
When you do a long press, it will turn off all the advance trac, stability control etc. The only thing still functioning is ABS , so now the car will be free to rotate and get loose. As well as come all the way around on ya.
2BigPups
NH
Jim
2021 Mach 1 M6055 (sold), 2023 F-150 (sold), 2026 Explorer ST, 2024 GMC Denali
In Track Mode, TC is still enabled but at a higher threshold. Toggle the TC switch once and TC is disabled. Found that out by driving on a wet skid pad this weekend and the TC would kick in rather abruptly even in track mode. :cwl:
Andy13186
Was advancetrac still on? Ive known the traction control is basically totally off in this mode, but I am not sure about advancetrac and I havent tried doing donuts in the wet or anything. I am assuming and hoping that advancetrac is still on at least some... since it doesnt say advancetrac off.
2BigPups
NH
Jim
Advancetrac was still on, but with TC off I was able to get a little bit of drift around the skid pad. Not so much with TC on in track mode.
pkim17
ATL GA
2020 GT Manual Performance Pack
I thought the Track Mode automatically turns TC off,
interesting to learn that TC can be turned off on top of the Track Mode!
Gotta try it next time, thanks
TeeLew
So Cal
Tim
auto car or manual? Magneride or not?
One downside to track mode is the aggressive throttle mapping makes it a lot harder to modulate the throttle at the limit,
Side note: The throttle map in track mode on the Eco ramps in quickly and then you're managing boost with a little engine that makes the same torque as a V8, but at a lower rpm, it can get busy. Anyway, to make things more manageable, I had my tuner make a linear throttle map. Well, they clearly use the quick throttle mapping to light off the turbo, because without it, the thing had pretty ridiculous turbo lag. It was hopeless. Live and learn, I had him put it back. I don't like a progressive throttle in general, but the turbo 4 made a pretty good argument for it.
