GTP
Deutsche Pony
- May 27, 2015
- Indy
- Website
- www.BambergAudio.com
- Philip
- 2019 GT PP1 A10 Outrageous Orange HPDE mods
Please create, and update as needed, a TLDR header at the top of your post #1, and then refer to the "answer posts", eg 96 & 278 etc.Glad it makes sense and is helpful. On the tips for sealing, go to post #96. That should get you started. The only thing I would change is the part A = 50% and part B is 50%. After I sealed the front and instrumented the system, it turned out that the front leaks are bigger than I originally thought. So instead of 30% of the total leak, it's more like 50%. To complete A+B, is 2 days. It's very tedious and takes time. There are leaks all over this system.
As far as the length of this thread, yes, I agree it's very long. I started in Oct 2021 with a question cus I was clueless on how a brand new GT w/ PP1 package could overheat really in only 3 mins on the track. Now 8 months later, there are answers.
After some advice from the Forum, inspections of the OEM cooling system, analysis, mods, and track time, I now have the cause and solution ... which is outline in the simplest possible form in post #278. As they say, a picture is worth a thousand words.
Took 8 months to have enough data, mod time, and analysis to be able to make that chart ... and a lot of interesting discussion and additional data from other members along the way in this thread.
So whoever is reading this now and wants the bottom line (cause & solution for post 1), go to post #278. On long threads, I usually start at the end and back up.
Let me add this ... are there other solutions .... yes, absolutely. But none more effective in my opinion from a cost, weight, and simplicity perspective for the non-competition track focus. Now the wheel to wheel guys, they will need more than post #278.
On your temps, they don't look too bad. 240F CHT. But as you hammer it and as ambient changes, they will be increasing. Good Luck and have fun driving the car. I wanted that gauge cluster but couldn't afford. Cudos. Cheers.
I am on MPS4 275s square and so far that's enough fun for me. I'm an intermediate driver. I love the big track mode display because I glance at the road speed on corner entry and exit as I build up speed. Then glance at the 3 middle gauges on the straight. (Or not, as there's nothing I can do other than slow down.) I also just made an adapter to flip my rear camera facing forward so that I can review gear, rpm, and speed around the track.
