Competition Orange
- Aug 25, 2015
- Columbus, Ohio
- 2017 GT350
I felt a bit of an improvement immediately after the BG trans fluid, but seemed to revert back to normal feeling within just a month or so. I wanted it changed since i was/am tracking it, but should be fine with OEM for your first fill.I'm running Redline 75w140 gear oil in the diff and have yet to see the rear diff heat warning (but then I didn't get the warning with the factory oil either). I also added some heat wrap around the exhaust pipes where they go around the diff to help manage the heat down there.
I'm running the BG syncro shift II transmission oil, but honestly I didn't notice much of a difference over the stock transmission oil. The BG stuff works fine, but I'd call it completely optional.
Square tires, camber plates for sure... and some way to hold you securely in your seat.
Stock PP swaybar endlinks bend pretty easily, although not usually enough to be detected from the driver's seat.
You can overdrive the stock brake pads, but usually only on tracks that are tougher than average on brakes. If you're advanced group, brake pads are a good idea.
I'm running Endless brake fluid (should be here Thursday), Millers Oil 75w110 diff as well.
My endlinks are slightly bent with factory bars, but as stated, not enough to notice and aren't getting worse.
Stock pads overheated pretty easily at mid ohio on back straight after a few laps. Then again, so did Gloc R10s. I'd add cooling ducts and Ti shims before pads personally. Then move onto pads.
Camber bolts are enough for -3 degrees of camber too.
Square tires and camber were the 2 best mods I've done.
