Toe alignment
kevinvan6000
Ontario
2020Mustang GT
Replaced the factory k-member in my car with a BMR one. Have an appointment on Wednesday to get an alignment at a shop which is about one mile away from my place. The toe alignment was way out of whack once everything was back together. I did a quick DIY toe adjustment in the garage just to get it to the shop. Right now i have it set 1mm negative toe (front slightly wider than rear). Just want check to see if that should be ok to get it to the shop. Thanks
MrMike
US
16 Mustang GT, 23 Bronco Wildtrak
When I put on the FP Track Handling Kit it looked like I had so much negative toe you could've used a protractor to read the angle of my wheels. You'll be fine getting to the shop, no worries.
