To all the manual drivers...
Nightmonkey
Germany
Jens
2020 Bullitt
I do this so I don't put the tensioning spring under load when parked/stored. I've seen these wear out where the shifter won't center itself as it is designed to do.
This may have had other causes...
A spring does not fatigue because it is compressed, the load changes fatigue it.
This is favored by incorrect design or poor material.
r-model
Toronto, Ontario, Canada
Current: 1987 GT, not stock :-) DD - 2001 F150
I always put the car in gear and only use the EB on steep inclines
Journey GT 435
MN
Craig
2015 5.0 GT Mustang premium pp / 2011 3.7 Mustang / 2010 Harley edition F150
If I am going to have to back up when I get in the car to leave, I leave the car in reverse. Only use the e brake on a hill.
TrueBlue22
Southeast Michigan
2022 2.3L High Performance Package Fastback
Shifter in 1st gear, parking brake on, wheel turned towards the curb if there’s an incline/decline for extra safety. Haven’t owned a manual in a while, but that’s how I learned 35 years ago from my father and it served me well for two decades.
dfesta
Cleveland Ohio
2015 Mustang GT 50th Anniversary Limited Edition
There are 2 centering springs and one would be overstretched (in tension) in the 1st or 2nd gear position which leads to the fatigue. I agree that it happens under tension, not compression, but it does happen if a vehicle is in long-term storage. I've seen it 1st hand on several manual transmissions.
m3incorp
Georgia/Colorado
James
In 1st gear (Reverse, when I back in to park), the emergency brake is engaged 100 % of the time when parked.
Nightmonkey
Germany
Jens
2020 Bullitt
Are you sure, that there are springs that get tensile force?
Would be a strange (= failed) design.
Springs are normaly designed for tension or pressure, they can not do both.
