Tire pressure
martin
New England
Ecoboost; coupe; guard; dark-saddle; MT; PP; Nav;
The tire information thing on the door says a pressure of 32 all round. I took my car for service and asked them to check the tires----and they set them at 28. What should it be?
Sal33n
Dayton Ohio area
Joe
2019 Ford Ranger, 2018 Alfa Stelvio
It should be set according to what the manufacturer tag on the car says. Did they tell you they set them to 28 or is it that you DIC is showing 28? Maybe there is a discrepancy between the DIC and their pressure gauge.
tcman54
Stanghead
Palm Coast, FL
Terry
2016 Ecoboost
They should be 32, I like mine a little higher at 34 makes the car more precise imo.
TC
martin
New England
They didn't tell me anything. The display is 28
Sal33n
Dayton Ohio area
Joe
Go buy a decent tire gauge and see what it reads then adjust accordingly. Chances are you're prolly gonna need to add 4-5 psi.
Also to note - tire pressure should be set and checked when tires are cold, not after driven on.
PJR202
KY
2016 GT PP Shadow Black
I've confirmed 32 via my own gauge on cold tires. It matched the TPS reading. I run 34-35 most of the time hot.
If that helps.
scott_0
Oxford, Pennsylvania
2016 Mustang GT
the recommended cold psi is on the drivers door jamb
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
The same recently happened to me. I didn't have time to change my oil and rotate the tires myself so I took it to the local Lincoln dealership and had them do it. I noticed on the paper work that it stated that the tech had adjusted my tire pressure and he also set it to 28 psi. To be honest, it kind of eerked me a little bit that he messed with it as I had it set to 32 psi (cold). The tire pressure normally rises 2°-3° when they warm up, so 32 is about perfect for daily driving to me.
In any even though, like the others have said, the cold pressure is 32 psi according to the door jam information. That's what I've kept mine on for daily duties and only otherwise adjust it when the car is going to see track time.
Terminated
GTFO_0009
MA
Marcus
Bagged & Boosted 50th Anniversary
The PSI on the door is what Ford recommends (cold), but you can divert from that and be okay. Comes down to preference, really. To compare, I run 28 in the rear and 30 front on mine...
JamesinLittleSilver
Little Silver, NJ
2015 Ruby Red Ecoboost Premium
I had opposite installed tires and was at 35 PSI was too high, go with 32 think car feels best there.
tedj101
Wilmington, DE
Ted
2018 Shelby 350GT Steeda springs, sways, camber plates, toe links etc: 14 BMW 328d
I agree. I started out at 36 and had to come down to 32. Actually, in the heat of the summer I went to 29 cold for track days. Went up to 42 and over 200 degrees hot. (These were Michelins. Pirellis run cooler and would melt at anything like that temperature.)
<TED>
F0J
Winnipeg, Manitoba, Canada
François
2015 Mustang GT
Keep in mind:
* Ambient temperature can affect pressure: colder == lower
* TPMS sensors seem to calibrate while the car is moving
* TPMS are probably off by 1-2PSI all the time (I have a reference gauge)
* Tires have optimal temperature, not pressure; so depending how you drive it might be worthwhile to have more or less pressure. Getting the right number is also very subjective.
For easy driving on the OEM all seasons, I keep them 31PSI in the fronts and 30PSI on the rears as read by my gauge. The TPMS gauges show 32/32. For spirited driving I'll drop the pressure by 2-3PSI.
I'd say 28PSI (TPMS) would be a little low especially if you drive fast and/or for a long duration.
tedj101
Wilmington, DE
Ted
Yeah, my TPMS seem to read about a pound high... Needless to say, i set them with a guage. It is both easier and more accurate.
<TED>
daytripper
E.TN
'13GT500,'15 GT
Get a reliable gauge before doing anything else. I have good luck with Accugage.I have 2 that I purchased several years apart. They both read the same and surprisingly match exactly the TPMS display. There are other good ones too.
