Tire pressure
draco24433
Kissimmee, FL
Alex
2015 Oxford White Mustang GT Premium
I do believe that tires come over inflated from the factory. Mine had 42 psi. I believe they do that because of the possible time it may take to get the car from factory to dealership and taking into consideration the time the vehicle will possibly sit on the lot.
souprmage
Portland, OR
2015 Mustang GT w/PP 50th Appearance
Or more likely in your case, the temp change from MI to FL in winter makes up for the high pressures. I doubt they set them that high to begin with.
Also for some people, it may be the change in elevation from Flatrock to wherever they are.
I generally like mine around 34-36 for most applications, except trailer tires, then its much higher.
analog
Central Oregon
2015 GT Premium PP
My tires (GT PP) had 42 psi in them. Built on 11/26 and checked pressure on 12/18. I'm at about 3300 ft elevation and it was about 40° outside. Lowered them down to about 35 psi and what a world of difference in traction even in the cool weather for summer tires. 42 psi from the factory was way too high.
souprmage
Portland, OR
And flat rock is 600ft elevation. 2700ft makes a difference in tire pressure, not 7psi difference, but a noticeable difference none the less.
Always good to check tire pressures when you get a car, the dealer should have done that in PDI I would suspect.
69mach1-395
central nm, usa
2016 RR GT/CS
I think some dealers top them off with nitrogen, put green caps on and feel they are doing you a service by going over 40 psi...
Stuntman
SoCal
many
Mid to high 30s is often an ideal operating range for handling. Adjust your pressures accordingly to compensate for temperature (ambient and as your tires heat up when driving aggressively/on track) and elevation changes.
I never liked those $15 digital gauges.
Asharus
Boca Raton, FL
Angelo
2018 Challenger Scat Pack
I noticed yesterday that my wife's 2013 Sentra will honk once the correct pressure is achieved, which is 33psi for her according to the door sticker IIRC. I found this feature surprisingly convenient. I'm wondering if our cars have the same feature, but did not find anything in the manual.
Oh well, if not, at least we have the PSI indicator in the dash. My GTPP was delivered to me with normal tire pressures. I'm surprised that some of you had them overfilled from the factory. Nevertheless, I keep an analog gauge similar to this in the car.
JimmyTwoTimes
New York
2015 GT Premium
I keep a similar gauge; check the pressure twice a week since there are no TPMS in my winter tires.
2Cool
Melbourne, FL
Ian
2015 Mustang GT Premium, PP in CO
Most often tire pressures are set high for shipping, as it reduces movement when strapped down.
Mine was at 42psi from the dealer. A lot of the time their PDI does not catch this issue.
Worst case I had was when I bought my '04 GTO new back in the day. Ship freight they actually strap the cars down and then apply more tire pressure to lock em in place. The car was at 60psi at all corners. I drove it home thinking that the Aussies had no clue how to make a car handle... worked a wee bit better with almost 30psi less at each wheel.
