THE NEXT BIG THING HIS HERE! 1003 RWHP ON PUMP GAS!!!!
Status
Not open for further replies.
Performance nut
TX
2018 Mustang GT A10
The pump by itself is $2500 normally, right now it is less. Comp cams are about $1500 for a baseline cost on that. ID 1050's are about a grand. $10,500 on the sleeper kit with the specs he mentioned in the video. No idea how much the tune will cost. So you all are looking at about a minimum of $16k … minimum.
Draklia
Dry Land
2017 GT
Looking at the price tag wasn’t that bad since I was ready for it.
theereverand
Theereverand
Newnan GA
2015 Mustang GT
Way to go!
Wolvee
Williamsburg
2021 Shelby GT500
So.... how much will it cost ?
If you have already have a return fuel system and upgraded port injectors will you be able to take advantage of upgraded DI injectors and DI pump with stock cams ?
Looks like we'd Add the cost of cams to the cost of an already premium fuel system. So maybe $3500 for just the fuel system?
Stymee
Delray Beach, Fl.
Joel
2019 Mustang GT
Looks like the DI pumps $2200 according to their site
The other parts I’m not so sure
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Pretty sure you just need one cam, not all 4.
olaosunt
Indiana
I meant just for the fuel system
Are the DI injectors ID’s ?
So if you minus the cost of the kit ...$5500?
I think I am good with E85 .lol
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
Hello, the kit price from XDI is $4999. That includes an in tank XDI fuel pump, bolt on XDI high pressure pump, set of 8 XDI high pressure injectors, and one camshaft with larger fuel lobe lift. We added a JMS Fuelmax for $489.
This was enough fuel for 1000 rwhp on our 2019 GT.
5ohh_kenny
Indianapolis, IN
2019 GTCS
The question I’m surprised no one has asked yet. Was any octane booster used?
Also, is this kit e85 compatible?
moffetts
San Mateo CA
Black Whippled 2015 GT PP
For those who can’t reliably get e85, this is a hell of an option.
Toydoctor
Seminole Florido
2018 Ford Mustang
I was curious about this too. So I did a little math.
Using a BSFC of .50 for 93 octane at
1000 hp gives a fuel consumption of 500lbs an hour. (Hp x BSFC = FC per hour)
Assuming the direct injectors are at there safe limits on E85 with a BSFC of .70 the math shows the system will only support about 714hp to the limit of the direct injectors.
(714hp x .70 = 500 lbs an hour)
I think this is why most don’t bother with modifying the direct injection. Port injection you have a limit to about 80% duty cycle. This works fine since the fuel will just sit in the intake port until the intake valve opens.
This can’t work with direct injection since the window of injection is so short. I’m not completely sure but I would imagine there is only about 180 degree crankshaft window for fuel injection. Where as port injection can utilize almost all 720 degrees of crankshaft rotation.
So in my opinion one would spend a lot of money on a system that will be limited to gasoline only. But also good for people with little to no access to E85.
chops44
TX
2018 Fathouse 1250R....1992 Gt 39k mile garage queen
Well done!! What were the corrected numbers and how much boost?
Status
