Thank you Hellion
noshine4mine
noshine4mine
East Texas
2019 GT A10 PP1 Hellion TT
Did you do new injectors too? What did that plug look like?
I got ID1050x injectors. and the plugs looked ok to me, but we put another set it in anyway per the tuner's suggestion.
18 Smoke
Columbus, OH
18 Mustang GT PP1 400a
Possibly try swapping #7 & #8 injectors and see if it follows and you get P0307
noshine4mine
noshine4mine
East Texas
Good Idea,
We are going to pull the intake this weekend to check the IRMC and I will swap those injectors at the same time.
Andrew@Lethal
West Palm Beach Florida
Andrew
Andy13186
Definitely takes time to get new builds dialed in, took me months to get my whipple all dialed in (had TB issues causing limp mode, then my transmission started leaking etc) Totally worth it in the end though.
noshine4mine
noshine4mine
East Texas
Thank you. that actually makes me feel better. slowly ironing out the kinks
noshine4mine
noshine4mine
East Texas
So I swapped the injectors, swapped coil packs. replaced plugs, removed intake and checked the IRMC, Checked and cleaned the O2 sensor (looked fine honestly). Misfires are still on cylinder 7 and 8. I have an appointment at the ford dealer tomorrow to have the "misfire monitor neutral profile re-learning" procedure done. I dont see what else it could be. as far as I know it didnt do it before the kit install. But I did have the oilpump and cranks sprocket replaced prior to getting the turbo kit installed and I know they remove the timing chains to do that. I hope the re-learn will fix it.
noshine4mine
noshine4mine
East Texas
Well Farge, Cylinder 7 and 8 are low compression. down 16% and 19%. Cylinder 4 is down 4% and Cylinder 5 is down 1%. Guess im rebuilding a motor. :(
Andy13186
Damn that is unfortunate. Do you think it may have been caused by oiling issues due to that oil leak possibly? Definitely would want to figure out what happened so it doesnt happen again on new motor. GL
noshine4mine
noshine4mine
East Texas
I dont think the oil leak was related. The oil leak was sloppy install. Likely it was weak and the boost just finished off the rings. Hopefully since they arent down completely I will be able to salvage the block. Im going to do a dirty rebuild. I will get the heads and block checked but I will probably just replace the pistons and rods, and get some ARP studs ( probably should get those on order, I hear the are a long time out filling orders).
Zrussian13
Phoenix
Damn that sucks. How many miles did you have on the car?
noshine4mine
noshine4mine
East Texas
Anyone know the flow rate on a stock Gen3 fuel pump (cant find the numbers anywhere)? What is the HP limit on a stock fuel pump?
What is more likely to cause compression loss on Cylinder 7 and 8. 7PSI of boost blowing out the rings or a lean condition?
18 Smoke
Columbus, OH
7psi will not “blow out” the rings. A lean condition will however cause ring land failure. I would install a good return style system. Initially, we put a DW400 in my brother’s Procharged car w/1050X. It made 735 on 93, but ran lean up top. He has since switched to a Fore twin 465 system and that solved the issue.
Zrussian13
Phoenix
Excessive heat has caused a few others to loose their #8 cylinder. Couple of the threads weren't even boosted guys iirc. Just running the ford performance pack and tracking the cars. That side of the engine seems to run the hottest.
Are you running a bap with the stock fuel pump?
