Nuked
- Sep 15, 2015
- Morgantown, WV
- 2016 Triple Yellow GTPP w/Recaros
- Vehicle Showcase
- 1
How much play side to side should there be in the Tension link on the bearing side where it bolts to the subframe? I have been trying to chase down a humming sound for the past year and starting to run out of ideas. Yesterday I pulled the passenger side strut off and took it apart and reassembled (shop that did it did not get the spring seated right). While strut was out I noticed there was a lot of play in the front tension arm bushing. Everything on the knuckle side is tight (both control arm ball joints and tie rod end).
