CEHollier
- Sep 6, 2015
- Prairieville, La.
- Charles
- 2015 GT Premium Magnetic
- Vehicle Showcase
- 1
Very nice. The graphite set off the blue. A little negative camber in the rear alignment may tuck those tires. I had a bad alignment (almost 0 degrees rear camber) and my rears tires stuck out about 1/4 inch. A local shop corrected to -1.5 and that pulled my rear tires nicely. Factory specs our cars to -2.3 degrees but with wider tires -1.5 degrees is optimum as advised by BmacIL. Are you using spacers?
Now you should get a chin spoiler and lower it , it'll be perfect
Btw have you checked to see if the stock center caps fit these wheels?
