SVE GT350 STYLE WHEELS!!!
bajaislander
Ohio
2016 Mustang GT PP
Got my wheels in today. Going with a square set up, 19x10 all the way around. One box had a corner crunched pretty good but all the wheels looked good. The faces of the wheels are well protected in the packaging. Once my TPMS sensors come in I'm ready to go have everything mounted and balanced. 19x10 weight is 24 lbs, pretty good in my book. :thumbsup:
Looks good! What made you pick 19s over the 20s?
scott_0
Oxford, Pennsylvania
when I got my 19x10/11's last week, figured Id weigh them, the fronts with the 285/35 G2's weighed in at 57lbs (same as my stock 19's with 255's) the rears with 305/35 weighed in at 60lbs, so not awful for their size I suppose
chain
PA
2017 Race Red GT
Just like the look of the 19's and they're slightly lighter. Just not a big wheel guy. I got the set up more for performance than looks. Save weight, better tires, and a square set up.
AutoX_GT
Columbus, OH
2015 Mustang GT Performance Pack - Black
I ordered the 20x10 gloss graphite packaged with the MT street comps staggered. 305 rear and 275 front. Should be here tomorrow, I'll post picks when I get them in.. Super excited!
Sighlense
Upstate NY
2015 Magnetic GT/PP
Sweeeeet...moar Graphite!
bobbyh
NE Ohio
2015 Mustang GT
Great!
I can't wait to see the photos as I have not been able to find any of the 20" wheels in a 305 on the rear for these.
Turbostang15
Michigan
2015 Ecoboost PP
Does anyone with the staggered set -305 in the rear and 275 in the front - have any pictures?
Will these work with a 1 inch drop?
Thanks
scott_0
Thanks
well, why wouldnt it work? what makes you ask this? LMR designed the offset Im sure knowing theyd be installed on lowered cars as well as stock height
fwiw, I have the 19x10 with 285's up front and 19x11 with 305's in the rear, Im lowered on BMR springs, not issues at all.........
Turbostang15
Michigan
2015 Ecoboost PP
Awesome!! Any pics from the rear?
cechk01
RVA
2016 DIB GTPP
thinking of getting the 19x10 all around, should i go 275/40/19 or 285/35/19?
scoggy_doogan
2016 GT Premium
I'm happy with my 275/40/19 square setup. Tires are a bit cheaper.
solodogg
Orlando
2015 Mustang Ecoboost
anyone been able to confirm if the OEM center caps or the Ford center caps that LMS sells will fit properly on the SVE wheels? These are definitely much cheaper than the alternative, and don't look to have any downsides thus far.
scott_0
my oem pony center caps would not fit without two layers of electrical tape wrapped around them, after that, they pop in tightly :thumbsup:
pro 5.0
Canada
2019 Mustang GT
OEM center cap is about .030 smaller in dia then the SVE ones, they will fit but they spin in the hole.
pro 5.0
Canada
2019 Mustang GT
I tried the same thing however after wrapping the tape around the center cap mounting tabs when I installed the front wheels the inside of the center cap was hitting the black cap on the front wheel hub and it wasn't allowing the rim flange to seat up against the rotor properly. In the end I just used the supplied SVE center caps they look fine.
