Suspension issue??
Mustanggirlie
Corona,CA
Athena
2019 Ford Mustang GT
Hi all! Need help please!
I had the CJ Pony Parts lowering kit installed on my car last year. I am noticing some creaking noise coming from the back end while slowly driving over bumps, turning etc.. Any opinions on what may be causing this noise?
Thanks!
Mustanggirlie
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
call cj, they will diagnose and tell you how to fix it!
16s550
Bay area
2016 GT M6 performance pack, whipple charged
I have something like that to. Maybe like rubber twisting sound or something..did you figure it out? I have steeda sport linear.
Mustanggirlie
Mustanggirlie
Corona,CA
Athena
Yes my hubby will be calling them. He had hernia surgery so can't check the car out. been waiting... :paddle: lol
Thanks
Mustanggirlie
Mustanggirlie
Corona,CA
Athena
Mine sounds more like a creaking sound.. IDK
Will let you know what I find out..
Thanks
16s550
Bay area
if it is rubber sounding, you may need to clock your bushings.
http://www.mustang6g.com/forums/showthread.php?t=44129&highlight=clock+bushings
On acceleration I hear some type of rubber squeak or something for passenger rear and same type sound in front I think driver side. But only at low speeds. Once above 10-15mph plus exhaust I don't hear anything else. At low speeds and parking lot almost sounds like an old squeaky car. Im taking car to local ford Mustang shop near me to see if he can clock the bushings for me.. Unless anyone else in Bay area knows a good place that won't charge arm and leg. Car seems to handle pretty legit though. .I have steeda sport linear. And about two finger clearance all the way around. Curious if it. Will drop more after..
T-S550-X
DFW, Texas, USA, Planet Earth, Milkyway Galaxy
Naji
DIB 2015 Mustang GT PP
A friend recently had the same issue. He thought it had to do with the caster and camber plates. After looking around the disassembled front shocks, he figured out that the rubber part that sits at the bottom of the strut had fallen apart. It was allowing the spring to move around which caused an audible squeaking like an old car at slow speeds. The parts from Ford were fairly cheap to replace and that corrected the issue. YMMV.
Tcstang
The Colony TX
2015 GT premium- Ordered
Yep that was me, the lower rubber spring seat had tore and the upper spring seat had cracked on the center plastic part. 20 bucks in parts from local dealer and squeak is gone.
16s550
Bay area
So I am going to install the other two and make sure I have right ones in correct location this weekend..now I've noticed I have some noise coming from driver front at low mph. I put my hand back behind wheel and it almost feels like the tire is touching the new koni strut slightly. How can that happen? Is there a way to fix?
Mustanggirlie
Mustanggirlie
Corona,CA
Athena
Ok so now I am confused.. are you all talking about the rear area? Or the front? Others have posted in my thread and I am thinking its about the front.
I am having a creaking noise when driving slow.. over bumps, dips. Pulling in to a parking lot. I called CJ Pony parts and he has no clue. :cool:
Any suggestions on my issue?
Thanks!
T-S550-X
Naji
@Mustanggirlie, check post #9. If the noise is coming from the front then thats probably your issue. YMMV.
16s550
Bay area
5mm spacer fixed my front end noise. Tire was touching koni strut.
