Bossdog
I purchased my 2019 PP 2 spring of 23. My goal was few mods, good street manners and robust HPDE performance. I was looking at used Mach 1's but in the end, I found a PP2, 6000 miles with cloth Recaro's (must have), MGW short throw shifter and Mach 1/GT350 spoiler at a good price, about $20K less than a new Mach 1 and $10K less than a used one. I knew I'd need to add an engine oil cooler $800 and a Diff cooler $900 - $1300 and camber plates ($200-$400).
Some things I learned this year preparing my car for the 2024 track season:
1) Ford doesn't measure oil temp, its calculated from an algorithm based off RPM, head temp and other such stuff. My Mishimoto oil cooler has a temp sensor port but finding a place to mount a gauge is a real headache! I highly desire a stock interior look. and even if you know the actual oil temp, your car ECU won't recognize the lower temp your after-marker oil cooler has achieved. Separating the stock Oil cooler from the engine coolant radiator may benefit the "calculated temp", but I'm not certain of that.
2) Fuel starvation on long hand left hand turns. On half tank or less, all your fuel slushes over into the passenger side saddle-bag tank and starves the fuel pump on the drivers side. The tanks have a slow rebalancing system but doesn't address track use. Apparently the GT350, GT500 and Mach 1 have a passenger side fuel scavenging system that manages this reasonable well, the PP2 does not. There are some inexpensive back-yard engineering solutions I'm not really comfortable with. A surge tank is very undesirable for a daily driver. (and expensive to install) no fire wall separation, etc.
Ai (After market Industries out of Australia) seems to have a solution that has "surge tank" incorporated into the drop-in, in-tank fuel pump. $2k in parts and likely $1K installation as I don't want to mess with this for safety and reliability reasons. The simple solution is to just HPDE with a full tank each secession, which I'm most likely to do for a few seasons.
3) The Pre-2021 S550 front wheel bearing flexes and deforms under severe load, enough to disrupt the wheel sensor information collection and "reset" your stability control and "freak it out" or turn it back to street mode in the middle of a aggressive track maneuver. The 2021 Mach 1 has a new, upgraded design that is more robust, but you have to purchase the new Knuckle and bearing hub for $800. Not terribly complicated, but ANOTHER $Grand! Yes, you can just pull the stability control fuse and turn everything off, but that kind of defeats the whole purpose of "track mode".
4) Ford Flex Fuel system for E85 tune; Again, in their engineering wisdom, Ford chose to not actually measure the alcohol content of the fuel in your fuel lines like GM does (and probably every other car company) they use the O2 sensor to "calculate" your fuel mixture. You can purchase an aftermarket bluetooth system for $400-500 to tell you exactly what your fuel mix is. Switching from a high octane to a lower is no issue but switching form low to high, you need to be patient, letting the engine run and "smell" the exhaust for a while and "learn" your fuel mix.
Another thing I learned, if you are going to thrash this engine on the track, you may be well to add oil balancing lines between the heads. None of the Coyote engines come with this from the factory (except crate engines) so it doesn't matter which version Mustang you have, GT, GT350, GT500 or Mach 1, they all will benefit from this mod. The nice thing is that Ford did put the threaded ports for both lines into the heads. They are only $200 but, you have to disassemble the entire top half of your car to get them installed between the fire wall the engine block. My Ford dealer has a race car guy in the service department so he convinced the service manager to quote me installation. $900. You can watch the installation video HERE. After watching the installation video, its the Best $900 I'll spend on this car.
I WISH I would have sprung for the Mach 1 !!! No coolers to add, No Fuel starvation issues, no Wheel hub / stability control issues on track, Comes with camber plates and your get GT350 intake and the Tremec trans on top!
This is my 4th track car so I know from great experience, no mater how diligent you research before purchasing, you will always learn more once you own it and do the deep dive.
As I said, I've done this before, I know track cars are an endless money pit! All these issue are well discussed here in the various Mustang6G forums, if you know what to look for! I just wanted to put all these things in one place to help others make better informed decisions.
Happy Tracking!
Happy Tracking!
