Strange Noise When Shifting - Any Ideas?
MxChamp24
Massachusetts
Kyle
2017 Ford Mustang GT
MxChamp24
Massachusetts
Kyle
This is my 2017 GT that I've had for 6 years now. Started hearing this noise about a month or two ago and its happening more frequently now. Very noticeable when taking off from stops, shifting into reverse, and occaisonally I will even hear it when accelerating hard. This is my daily right now, so would love to hear if anyone has experience with this or ideas!
Timbuck
Australia
Tim
2017 s550 6r80
Tighten your wheel nuts. I had / have the same noise after wheel bearing replacement because I used the OEM nuts again ( once use only , as they are torque to yield ) I have a new set to put on.
In your case just tighten the axle nut and it will be fine.
SheepDog
Colorado
Dax
What Tim said. In addition to this, install a jam nut with some blue or orange thread locker, and never have this problem again. Torque the jam nut to 100 ft/lbs
https://www.mcmaster.com/97013A118/
MxChamp24
Massachusetts
Kyle
Okay perfect, what even causes this? Just not tightening stuff back? Ford recently did new brakes and fixed a pinion seal leak about a year ago.
Timbuck
Australia
Tim
2017 s550 6r80
It’s pretty common across the S550 planform that axle nut tend to loosen over time , it’s natural movement that causes it. Also bearing problems are very common , heavy car , big tyres lots of load on the bearings.
