STFT swinging/Idle Stumble post cam install.
gcadorette13
PoopStang
Missouri
Currently on a base tune after I installed cams on my 2016. After the car warms up it idles really rough and usually dies. STFT's swing about 30% both ways. The only changes I made was the cams and the fews parts that go along with that. No CEL's
Car ran pretty good before the cams. It has new O2's, brand new MAF. The CJ has been on the car for a few years so i don't think it's a vacuum leak from that. I have removed the intake a couple times in hope that it was something that simple. Logs are showing cams are at 0 during idle so it might not be the phasers or solenoids. I am thinking of replacing the solenoids just because they are pretty cheap.
Kind of at a loss on what to try next for troubleshooting. I want to rule out everything before I just take it to a shop. What do you guys think?
gcadorette13
gcadorette13
PoopStang
Missouri
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
A data log would be helpful. Have you asked the tuner?
You said the MAF is brand new…is it backwards?
gcadorette13
gcadorette13
PoopStang
Missouri
I will take a long data log today to send off and I'll toss it on here. The MAF is installed correctly.
gcadorette13
gcadorette13
PoopStang
Missouri
Have you tuned back to stock and then reloaded tune?
I have not done that yet. I will give that a shot and see if it does anything.
MKL_DS
Central Forida
2020 GT PP1
Can’t expect a base tune for cams to be on point. Gonna take a log or 2 to dial in idle and drivability.
EFI
Masshole central
5.Br0
Sounds like that base tune is not quite right for your setup and will need some adjustment from your tuner.
That would be my first point of contact about this, not the forums.
gcadorette13
gcadorette13
PoopStang
Missouri
That's what I'm thinking. I loaded up the old 93 tune that I knew worked and it idles waaayyyy better. I can tell the cams are not the happiest while driving, but it's a good starting point.
gcadorette13
gcadorette13
PoopStang
Missouri
That's starting to makes sense. I was hoping it would idle at least, but we're working through it.
