Steeda Billet rear shock mounts Necessary?
Driv3n to Dr1ve
Washington
2016 Mustang v6 6 speed manual
So I’ve kinda settled on the non-adjustable steeda shocks+struts +camber plates+progressive springs. I track my GT maybe 3-4times per year and daily drive it.
i’ve seen a few posts noting steeda billet shock mount failures, so I’d like to know if my stock mounts are sufficient for non-adjustable shocks.
If anyone with @SteedaTech could chime in, have improvements been made to the billet shock mounts?
GregO
Illinois
S550 GTPP
I’m not Steeda Tech but, I’ve got 60K miles of year round Midwest crappy roads on my Steeda Billet mounts and absolutely zero issues with Steeda Ultralite linear springs and Ford Performance Struts
There’s other option now but Steeda was the first to market.
I’d purchase the Steeda mounts again.
Your stock mounts are fine but there is a certain amount of deflection built into the vulcanized shaft mounting area.
Driv3n to Dr1ve
Driv3n to Dr1ve
Washington
That’s great to hear, thanks! I’ll probably skip the shock mounts.
MrBD1348
Chicago, IL.
'22 GT MT-82
Skip the camber plates as well, you don’t need them.
did you do camber bolts instead? Or just the ford strut to knuckle bolts? I got the same shocks and struts but bmr sp083 springs. I have camber bolts in place right now while the springs settle
GregO
Illinois
S550 GTPP
OEM Ford strut mounting plates and no need for camber bolts either.
We hit -1.5° / -1.6° camber with all OEM hardware and stock strut through hole diameter.
tj@steeda
Timothy
It's important to note that a limited number of incidents have occurred due to the extreme lowering of cars, causing excessive stress on the rear shock mounts, regardless of whether a Steeda mount is used or not.
These mounts are commonly known as "weak" points on these vehicles. However, for peace of mind, we have sold thousands of these units and they have proven to hold up exceptionally well when properly installed.
Let me know if you have any other concerns - you can reach me at tim @ steeda .com
Best Regards,
TJ
Driv3n to Dr1ve
Driv3n to Dr1ve
Washington
Best Regards,
TJ
That’s great clarification, thanks!
GregO
Illinois
S550 GTPP
He said he daily drives the car and tracks maybe 3-4 times a year……
Camber plates or bolts are not needed to hit the street performance alignment angle I listed.
RagmopInKona
CEO
2020 Mustang HHP
Ok, insert stupid question here.
I come from the land of unequal a- arms , the S550 is the first Strut based car I will track and push. What do these plates do.
I am Assuming make the camber easy to adjust. Do they have markings or do you add those yourself, So at track you can set it, and when back street driving you can put it back.
Sorry if this seems stupid, but all my past track cars have been A -arm set up inthe nose and 3 link long arms in back.
shogun32
Northern VA
indeed.
But -1.5 hardly qualifies as a 'performance' alignment. IMO the minimum should be -1.8F if not into the low 2's. Rear about 0.5 less than front.
