Starting issues/cranking over
Mrpopper239
Naples Florida
Leonardo
Hi guys! I have a 2016 mustang GT. And my car is acting strange...when I push the start button to turn the car on it sometimes struggles to crank over and it makes what seems to be a grinding noise coming from what I believe is the starter... I need advice as to what to do. Battery is good. Should I just replace the starter. Car also has a new alternator. Thank you!
ORRadtech
Atlanta, Georgia
How do you know the battery is good?
Have you checked both ends of all battery, starter and alternator cables for corrosion and tightness?
Good parts stores can check that the starter is good.
Mrpopper239
Naples Florida
Leonardo
Battery is good reads the right voltage and connections are tight to battery no corrosion there either. Haven’t checked the starter connections
NoVaGT
Northern Virginia
2019 PP1 GT Kona
Battery is good reads the right voltage....
I'm still going with it's your battery. It reading the right voltage may not necessarily mean it's still good.
Unless you've replaced it, it's probably 5-6 years old now.
And it's also smart to start with the most obvious thing, and work your way from there.
Mrpopper239
Naples Florida
Leonardo
It was replaced about a year ago only changed the battery once since stock I don’t think a battery would go bad that fast
NoVaGT
Northern Virginia
2019 PP1 GT Kona
If I were in your position, I'd replace it even though it's only 1 year old. It should have some warranty that covers replacement, and it's the most likely suspect for your issues.
Mrpopper239
Naples Florida
Leonardo
Hmm interesting just doesn’t make any sense to me. Thank you for the help
NoVaGT
Northern Virginia
2019 PP1 GT Kona
ORRadtech
Atlanta, Georgia
You've got to eliminate the basic stuff first.
What resting voltage is the battery at?
If you believe it to be good then take it to any parts store and ask for a load test. It's free at most places.
The wiring can be good at the battery but what about the other end? Most never check that. Also, a loose, meaning not tight enough, not necessarily wobbly loose connection anywhere in the system can cause very odd issues. And as I said above, good parts stores can check the starter. Unless you just want to throw parts at it...
larr12
Alberto
2020 Mustang PP1
Whats the CCA of the battery?
NoVaGT
Northern Virginia
2019 PP1 GT Kona
larr12
Alberto
2020 Mustang PP1
NoVaGT
Northern Virginia
2019 PP1 GT Kona
You can test a 600CCA battery and get 12.5-14 volts but only 200-300CCA.
I just noticed the car has a new alternator.
Here's my guess;
OP had similar issues in the past. Replaces battery. Still has issue. Replaces alternator.
Replacement battery was ruined because the alternator was shot. Now car doesn't start.
Of course that's a complete WAG.:cwl::cwl:
