Stalling, bucking, and Drivability issues at operating temperatures
2023Mach1
North Carolina
SuperChargeMe
2023 Ford Mustang Mach 1
The bap and it's controller have long since been removed, ya?
How smart is the fuel pump? Does it not detect pressure on its own? Or is it a dumb device that the ECU must command on/off for flow and pressure?
BAP was removed. All back to stock connections.
I think it’s a dumb pump commanded by the ECU…
Pressure at the lift (I’m assuming that’s the low side pressure) was very close to matching.
But rail pressure was way off.
check my screenshot out above.
2023Mach1
North Carolina
SuperChargeMe
Curious if maybe one of the coil packs are bad.
I have not done a tune up yet but the only thing that points me away from that is the fact that it runs perfect in open loop. (Before sensors are used)
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
These cars only run open loop for about 15 seconds when first started. Not enough time to say if it is running perfect or not.
2023Mach1
North Carolina
SuperChargeMe
Hmmm… mine seems to run OL until it’s warm.
Pistol_91
Clearwater
2020 mustang GT
Like K4 said. They should only be in OL for seconds. Not minutes while your car warms up
K4fxd
NKY
That shouldn't be, once the widebands heat up these cars go into closed loop.
2023Mach1
North Carolina
SuperChargeMe
That makes since. My car keeps dropping the CL- normal when the pressure gets to high so it seems to be doing it as protection to the engine.
