Square 19x11 setup- are extended REAR wheel studs also needed?
BigChief
Jax, FL
68 Coupe, 19 GT350
Hey all, thanks in advance for the help. I know we need extended front studs and a spacer to run 19x11 ET52 wheels and tires, but are extended REAR wheel studs also needed? Would a 19x11 ET52 on the rear work with the stock wheel studs and lug nuts, or even the open ended lugs?
lo-fi
NE TN
2018 Mustang GT (Zero Options, Orange Fury)
If you aren't installing spacers you should be fine.
BigChief
Jax, FL
68 Coupe, 19 GT350
Thank you both that will make things easier/cheaper lol. For the fronts- Is it easier to just get new hubs with the longer studs already pressed in, or just get new studs for the existing hubs? The car has about 6 track days and only about 11k miles on it right now. I dont see the point of new hubs, but if it's easier to do it that way or may improve their longevity then maybe it's worth the extra money?
mavisky
Cumming, GA
Kyle
2018 GT350
It's not hard to install the studs, but unbolting a hub and bolting another hub in is easier depending on what tools you have access to.
spankybranch
Orlando, FL
instagram.com
Geoffrey
2016 Fiesta ST, 2019 Edge ST, 2022 Mach1
As other already answered, your essentially running 4 rear wheels, so you only need to make accommodations to run them on the front (studs/spacers)
Metz3020827
Arizona
Connor
2017 Mustang GT
I have this exact setup for real wheel including offset, nothing additional needed. Throw them bad boys on.
buggy whip
ca
ford pinto, '16 GT350/OxFo/ Trac/Stripe delete
Just put this set up on my car.
Apex SM-10 / 19x11 ET52. Riding on Michelin Pilot Super Sports 305-35/19.
Changed the front hubs with longer lugs and using 25mm spacers w/ open ended lug nuts.
Love this set up. Unless you have a Quick Jack, putting a regular floor jack under the car is a no go. Use regular ramps and there's no issue with sliding the floor jack under the car.
Dana Pants
Burlington MA
Dana
2018 GT PP1
I broke 3 rear studs and then gave up and put APR studs in the back as well. Now life is good.
buggy whip
ca
Bummer !
You must be pretty hard on that ol' horse...
justBrad
Tennessee
Brad
Nissan Murano
This is a great thread. I’m thinking of the same setup.
if I changed to two ford performance rear wheel hub on the front plus the spacers would I be able to use the original lug nuts? Or would I have to switch to open lug nuts?
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
Yes, the rear will work with the stock wheel studs and your capped lugs nuts
