Spring install on magneride
Spock5.0
Conroe, TX
Christopher
2019 Mustang GT A10
I’d like to install the ford performance W springs on my 2019 PP2. I recently traded my old 2019 A10 base gt for a PP2, and I had BMR SP083 and ford performance track shocks, as well as a number of other bmr and Steeda parts. I’ve installed and now uninstalled the springs and struts a number of times on the old car, so I’m very familiar with the process.
Let me just say that the magneride on the PP2 is on a whole other level than my previous setup. But with the 305/30’s all around, there is a decent amount of wheel gap I would like to eliminate, and I was thinking about the FP W springs since they say that the PP2 doesn’t need a recalibration for the magneride module.
A few questions though:
1)Are there any special concerns when installing springs on a magneride car? Previously I’ve just hit the top nut on the front struts with my impact, just short bursts to get it loosened/tightened. But inevitably, the shaft spins a bit but wasn’t concerned with traditional struts. If I get the Steeda strut socket that allows for torquing while holding the shaft, is there any concern with damaging the magneride strut if the shaft does spin a bit at some point?
2) With the aggressive offset and 305’s in the front on the PP2, will I have any clearance issues with the front fenders? I previously had SVE pp2 replicas on the old car, but those weren’t nearly as aggressive of an offset in the front, so I never had an issue.
3) Have there been any issues with springs lessening the life span of the magneride shocks? I usually upgrade shocks with springs, but obviously want to keep the magneride.
o-man
Durham, NC
Oscar
2019 Ford Mustang Bullitt
I didn't do anything different when I installed springs on my MR Bullitt. Have somewhere between 25-30k miles on them with no issues
Arknsawchuck
Cabot, Arkansas
Chuck
2019 Mustang GT PP2
Just did the spring change on my PP2 and everything when the same as on my sons 2017 GT. Make sure you get the springs for a magneride car because they are different.
If you stay with 305/30 tires you won't have any rubbing issues with the factory or SVE wheels. I have both sets. The front will rub with 305/35s.
I haven't had mine on long enough to know about life span, but I'm leaning to no. Since they are made for the magneride suspension and don't drop the car much at all I don't think it hurts anything. Don't expect much more than 1/2 inch drop. Maybe when it settles in it will be a little more but so far that's all mine did and that was in the front, I don't think the back is even that much.
Spock5.0
Conroe, TX
Christopher
2019 Mustang GT A10
Yeah I like that the drop is minimal, I still have to drive the car in downtown Houston from time to time.
Glad to hear no issues with rubbing either for the same reason noted above. As mentioned, I had the BMR handling springs on my old base GT, and I think that was about a .75” drop.
My biggest concern though was damaging the magneride shocks. Just used to the traditional style factory shocks that blow with the slightest increase in spring rate. So, glad to hear they seem to be fine with the Slight increase in spring rate and drop. And I was just curious about the removal of the factory top nut, as CJPP and AM magnetite specific videos on YouTube just show them using an impact, which I’ve personally done a number of times, but never on a shock as expensive to replace haha
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Disconnect the ride height sensor before you drop the spindles. Otherwise install is the same. Have your ride height recalculated and get an alignment after you’re done.
Spock5.0
Conroe, TX
Christopher
2019 Mustang GT A10
Yeah I will for sure be getting an alignment. I already have steeda camber plates and roll center/bump steer kit and BMR rear toe arms that came off my old car. Can I do a ride height recal with forscan, or does it have to be done by dealer. And any idea on cost to do so?
kz
West Chester, OH
Mustangs & F150
You technically should zero ride height sensors as it'll change when you change the springs.
As for getting the top nut off - I got mine off with an impact.
