Spacers To Get The Wheels Flush?
WF_GT350
NYC
Bill
2007 GT500
Thinking about 20mm rear, and 30mm front eibach hubcentric spacers. They are well build and quality. I used them on other vehicles. I don't plan to track with them, however I know a few guys that do.
Anyone ever done this on a GT350? The front wheels are just too far in and wanted it more flush.
lenFeb
USofA
Len
2019 Shelby GT350 #K0110
The car is sitting low. I'm afraid with the spacers wheels be hitting fenders on road bumps.
WF_GT350
NYC
Bill
2007 GT500
Would they be safe to track and drive with if they don't rub?
proeagles
Covington, LA
Scott
2019 Shelby GT 350, 2019 BMW X3, 2019 Honda Civic
Personally I think this is a bad idea just for the sake of looks. It alters the scrub radius of the tire throughout its movement and will likely touch the fender at an inopportune time.
Grintch
Hunstville
2015 GT PP
I would never run bolt on spacers at the track. It at least doubles you failure rate/points of failure.
And 20mm is too thick for bolt through spacers unless you get longer wheel studs.
It's not a standard GT, the GT350 is already pretty darn flush stock. Adding spacers is likely to result in poke, and tires hitting the fenders.
svttim
Wisconsin
2019 GT350R
I have run Spacers on track (Not my 350) with recommendation of KOHR Motorsports. But, They were not cheap ones
proeagles
Covington, LA
Scott
We're talking GT350 here so whether you ran spacers on another car or not is not relevant.
svttim
Wisconsin
2019 GT350R
Its relevant from the safety aspect. They are safe. Wether a certain size or offset works on another car is irrelevant
proeagles
Covington, LA
Scott
You can't say for sure that they are safe on a GT350 just because they are judged to be safe on a Honda.
svttim
Wisconsin
2019 GT350R
Hub Centric Hubs are safe period. No matter the car if the right part is used.
proeagles
Covington, LA
Scott
Finally said something I agree with, the right part. If the OP has been following this BS I hope he does his research, picks the right part for a GT350 if there is one, and then checks his wheel studs for proper length because his stock ones probably won't work any more. I've seen people do this, get about one full turn on the stud thinking they are good only to have the lugs back off and lose a wheel.
Grintch
Hunstville
2015 GT PP
Spacers are perfectly safe. I use bolt through spacers with extended studs.
You will need extended studs and the rear ones are a bi$@#$@$ to change.
What did I say? Bolt on spacers are bad, thick bolt through spacers will require extended studs (but are OK).
proeagles
Covington, LA
Scott
After all this fine advice from people you don't even know I'm curious of you are still going to install spacers and if so, what size.
