So When??
Houston Kid
Houston Kid
Houston, TX
So another week and no real numbers from Ford. Oh well.
Hack
Minneapolis
Mustang, Challenger
I for some reason have a strong feeling that the reveal of the GT500 will fall sometime after July 18th. :angel::giggle:
Houston Kid
Houston Kid
Houston, TX
What is the significance of July 18th?
Houston Kid
Houston Kid
Houston, TX
So even GM knows to set a solid date and do an actual full reveal on said date. That is about the only thing they do better than Ford.
5.Oh Crush
DMV
Ra
Mustang
Corvette was just named most deadliest car. Not the greatest review.
Ninjak
Posting from the Shadows
The Shadows
David
2024 Dark Horse Supercharged 2024 Bronco Raptor 1968 GTA Mustang
Well hopefully we will see something soon. I would like to know the numbers. I will not be attempting to get one though. The ADM's will be crazy here in S. FL. Just to many people willing to pay top dollar to be the first. Besides, I am happy with my GT350. I will not be sad driving her around. (Also I spent my GT500 money on Betty) :wink:
Gogoggansgo
Midwest
Billy
2015 mustang GT
A couple of problems with your post:
1) Ford isn’t limited to 12 psi.
2) Fords overhead cam engines respond better to boost then chevys pushrod engines.
3) not sure your point about tunes is valid. It seem the Fords usually have higher ā€œtune onlyā€ gains.
Let’s see where things go.
Im thinking the number is pretty healthy.
Ford said end quote ā€œ12psi Of boost and it’s the same unit off of the zr1ā€
When it’s comes to boosted engines having super high flows heads is on the short list here lol. I’m telling you point blank the stock tune on this car will be more aggressive than what Chevy did with the zr1, due to displacement and a lower redline. I’m
Not knocking the car but it’ll be interesting to see what it’ll do with mods. Knock would be my main concern
Rjames18
Houston
RJ
2018 Mustang GT A10 Orange Fury
You can't compare blowers when the motor is completely different lmao
Darkane
Alberta
2016 GT350 Base
You absolutely can because the blower moves a certain volume (CFM) of air. That’s the constant.
The rest is speed (rpm), compression, timing etc.
The goal with higher flowing heads is to reduce the restriction into the air pump (engine).
Think of boost as the resistance of air entering the pump. Therefore, higher flowing heads would allow less resistance of air with the same pressure which would equal more power.
Anyway there’s a lot more to it.
9secondko
Irvine, ca
2003 cobra
I don’t remekber Ford giving out the PSI. If they did, that’s interesting. Just that it was the same unit which produces (nearly 14 peak) in the Corvette. Would you mind posting the source? The only thing I’ve seen with that number is a road and track article that quotes Ford on some thing and then adds their own, non-quotes details. The 12 number was added by R&T and not quoted.
Ford was rolling with 15 psi on the ā€˜13 gt500 which used a 5.8 that doesn’t compare to the 5.0 now. Let alone the 5.2 CPC. And the 5.0 was built for supercharging from the beginning. There really isn’t anything stopping them from running 15 psi now.
9secondko
Irvine, ca
2003 cobra
Boost is more like air pressure in the engine.
It’s not only at the entrance, but even in the exit. It’s why headers will lower boost, but gain power.
