SCCA F-Street Setup. What's Everyone Done so Far?
Schnupper
Chicagoland
Black
Yeah factory PP suspension.
Grintch
Hunstville
2015 GT PP
If I was still a member, I would write a letter pointing out that FS is the only Street class where one car got 100% of the trophies. The top car was faster than the supposedly faster BS class, and they should either bump it to BS or drop the "fast ponycars" from BS back to FS.
z3papa
Illinois
2011 BMW M3
I no longer have a dog in the fight but this chorus to move the ZCP M3 out of FS is going to fall on deaf ears. It can't happen in 2020, and by 2021, there will other cars moved in. Better plan for the PP2 and possibly the 1LE coming to FS in the next year or so along with possibly the F80/F82 M3/M4. Times are a coming with faster, better FS cars.
  • Like
Reactions: kz
Schnupper
Chicagoland
Black
We got a nice bump in PAX for FS. We will see how I do in the 2020 season for the chicagoland events. It will by my first season with the chicago SCCA and TSSCC. I plan on getting some adjustable shocks/struts but unsure which ones i want to get. For the smaller clubs I run with I won't be using the mustang this year so i can save on tires.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Budget?
I'd probably do Konis or have these revalved by Pro Parts USA:
https://www.americanmuscle.com/rtr-...able-shock-strut-kit-1517-gt-ecoboost-v6.html
Dana Pants
Burlington MA
Dana
2018 GT PP1
Tire costs are an issue and we all have our own strategies... I do my own mounts, flips, and balances. Saves a lot of cash compared to relying on shops to do so. The extra flips and rotations cuts down on replacement rate significantly... especially when you get into the wear bars and no shop wants to touch em anymore.
Schnupper
Chicagoland
Black
That's a good idea. This is how my first set of tires wore in the front. I bet a lot of it was due to me learning and lots of driver induced understeer early in the season. Now that i have a decent alignment and am comfortable with the car I hope I can make it thru the whole season on one set of tires.The rears wore really well.
Fronts
Rears
Dana Pants
Burlington MA
Dana
2018 GT PP1
Fronts
Rears
meanwhile in flip it land (inside rear shown)
To be fair, the last 2 or 3 events the tires lost their bite.
Also, your front tires look like they had a lot of runs left before the traction compound disappeared. If you did a front-back and/or inside-outside dismount you could get a lot more runs from those tires.
ahhter
2017 GT PP
Is there a particularly good class-legal set of bumpstops that people prefer for F Street? Not sure how critical it really is for a Mustang since even with the rebound cranked up it probably doesn't drive most of the course on the bumpstops like a prepped ES Miata does (my other car) but figure I'll check that box when I pull everything apart to install Konis this winter.
ahhter
2017 GT PP
It hadn't occurred to me to try manual tire mounting/balancing on a setup the size of the Mustang's wheels/tires. Other than the pictured irons, mind sharing what tools you're using to get it done? Bubble balancer for the wheels?
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
Really, $25 to rotate, $100 install balance/align check get expensive. I bought Steeda jacking rails to rotate tires & change my own oil. Changing tires is probably too hard for me but, I got younger friends who'd help. I lost 55 lbs to throat cancer, I'm a little light at 149 lbs & gaining.
Dana Pants
Burlington MA
Dana
2018 GT PP1
Windex
Bead buster XB-455
4x harbor freight tire irons
Rim protectors probably from eBay (shown)
Plastic clamp on bead depressor (shown)
https://www.ebay.com/itm/Bead-Depre...Machine-Low-Profile-Tire-helper-/253319042579
Big air compressor
~$100 bubble balancer off eBay.
Harbor freight stick on tire weights
The Mustang tires are easier than the tiny tires on an STS civic in my opinion. Watch like 100 YouTube videos on how to do this before giving it a shot. It’s not hard but it’s also not so intuitive.
NightmareMoon
2016 Mustang GT PP
Windex
Bead buster XB-455
Big air compressor
How long does it take you?
Dana Pants
Burlington MA
Dana
2018 GT PP1
It looks like I need about 3 hours to mount and balance 4 tires. I wouldn’t want to go much faster because anything stupid rips paint off the wheels.
Keep in mind that two tire shops failed and it took 3 autocrossers with a machine to get these tires mounted the first time... so getting it done on the first shot with one person is already a huge success.
