S550 Rear cradle/diff bushings
Brent S550
Perth western Australia
Brent
2019 Mustang GT
Hello, looking for some real world experience in relation to upgraded rear subframe/differential bushings. I have a 2019 S550 with bolt ons and E85, will be adding the whiteline KDT953 subframe bushings and superpro TRC4758 diff bushes soon. Are the steeda/bmr subframe braces really necessary as well? Looking to eliminate wheel hop and cut a good 60 foot time without the added parts/weight if not required, thanks.
horsepower addiction
Arizona
Nate
s550
Subframe braces are definitely a good idea. The rear subframe mounting holes are bigger than the bolts so under hard corners they have been known to move. On the strip I don’t know if it would be worth anything
Benjamin Hundred
Los Angeles, CA
Benjamin
2018 Mustang GT230 Convertible
I’ve completely built mine out, including the KDT953 and Kelltrac diff bushings. I’ve listed below what I’ve done, very minimal NVH, daily drives like a dream and handles like it’s on rails.
I highly recommend the Kelltrac diff bushings, especially if you’re trying to stay low NVH/daily the car.
  • Front GT500 20x11 305/30/20 Continental DWS
  • Rear GT500 20x11 315/35/20 Continental DWS
  • Front 1" Mishimoto hub centric spacer
  • Front BMR SP089 Minimum 1” Drop Springs
  • Rear OEM base springs (ride quality and clearance for larger rear tires)
  • Both front and rear Eibach bump stops
  • Front and rear Steeda Comfort/Active shocks and struts
  • Ford PP front control arms
  • SR Performance strut tower brace
  • 6 Piston Bullitt Brembo brakes
  • Whiteline KDT953 subframe bushing replacements
  • BMR BK081 LCA Bearings
  • Ford Performance toe link bearing
  • Ford Performance toe link arm
  • New OEM vertical links
  • New OEM away bar end links
  • GT350 front and rear sway bars (non-R)
  • Kelltrac rubber/billet differential bushings
  • OEM convertible rear subframe brace
Slow Yote
Central Ohio
Seth
2018 GT PP1
If you’re already doing it, you’re going to pull them anyways, spend the little bit of extra money and do it at the same time.
