Shark77
He probably means the M235i, which was slower than a 2012 GT around Willow Springs. Both were driven by Randy Probst.What's an M2?
2012 GT: 1:25.77
2014 M235i: 126.37
BMW will be releasing an M2 at some point. The M235i is not a "real" M car. It's basically the 2-series with the M-sport package. Great car, but no GT killer. However if the M2 had the power-plant from the current M3/M4 it will definitely pose a serious threat to the s550.He probably means the M235i, which was slower than a 2012 GT around Willow Springs. Both were driven by Randy Probst.
2012 GT: 1:25.77
2014 M235i: 126.37
I'm willing to bet, if we can find a bare M4 shell (with some good pics on the pans, top and bottom), we might get an idea where it's going...
Just a thought...
And not chopped to pieces, the complete car.There is some stuff from these links but I don't know how much you can tell from it.I'm willing to bet, if we can find a bare M4 shell (with some good pics on the pans, top and bottom), we might get an idea where it's going...
Just a thought...
The front suspension is not too different from the S550, but the rear uses multi-link with 5 hard hub mounting points. I am not sure if that is needed for a car this size and weight.There is some stuff from these links but I don't know how much you can tell from it.
http://www.bmwblog.com/2013/10/19/dtm-race-driver-bruno-spengler-helps-tune-chassis-bmw-m4/
http://www.bmwblog.com/2013/09/25/breaking-technical-specs-new-bmw-m3-bmw-m4/
http://www.bmwblog.com/2014/03/12/bmw-m4-clear-construction-model/
https://www.press.bmwgroup.com/asia...3-sedan-and-new-bmw-m4-coupe&docNo=T0148404EN
And here is tons of stuff for the 3 Series that it is based on, but I'm sure there are a good amount of changes for the M3/M4
http://www.f30post.com/forums/showthread.php?t=858575
My guess is the Mustang rear will be a bit more lively, more communicative, but the M3/M4 will be more compliant and more isolated which seems to be the direction of BMW.
2012 GT: 1:25.77
2014 M235i: 126.37
From what I've heard, the Mustang has the same too.The M3/4 has a solid mounted rear subframe with low compliance bushings.
