Rumor - The GT500 thread
Zombo
befejezett
2016 GT350 Track Pack - Race Red, Blk Roof - G5405
Thanks for the input.
If you look at the N/A engines in a specific torque comparison, the 4 valve (1.39 lb-ft/CI) does have ~15% advantage over the 2 valve (1.21 lb-ft/CI). The 4V is obviously a higher performance engine. The specific HP advantage comes from the higher revs and improved flow at high revs of the 4V. I would think that this would not be as big a factor on a FI engine.
Will adding a supercharger reduce the redline from the current 7500? I suppose we will see when the GT500 is introduced.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
And Ti-VCT.
65Terdlingua
Kansas City
1965 Mustang
Serious questions: A Demon makes a supercharged 808hp (non race fuel) with 376 cubic inches of displacement; a 5.2L engine (315 cu.in.) with the same specific HP would make 677 HP. With the HP numbers being talked about (>700), what about the anticipated GT500 engine would make it have this level of specific power? The Demon uses it's A/C circuit to assist in cooling the intake charge. Is it anticipated that the GT500 will use similar tricks?
Heads and cams, heads and cams.
Zombo
befejezett
And Ti-VCT.
The ZL1 engine has variable intake and exhaust valve timing?
Any concerns whether the 5.2l spray bore block can handle the combustion pressure that would be generated by the level of boost necessary to produce such HP?
65Terdlingua
Kansas City
1965 Mustang
The Trinity motor did it fine to 662hp, and GT350 blocks seem to be handling it well.
Epiphany
Global
I like to disassemble things.
I was told that cylinder wall thickness was something that needed to be addressed for this application. No doubt the block for this application has been gone through and been beefed up appropriately. It'll be interesting to see how they went about it.
BmacIL
Enginerd
Naperville, IL
I was referring to the Ford engines.
65Terdlingua
Kansas City
1965 Mustang
The new 5.0 block looks very stout. I would assume the 5.2 is also based off of this architecture. Not sure if [MENTION=10281]BmacIL[/MENTION] would have info on this or not.
https://www.mustang6g.com/forums/attachment.php?attachmentid=150658&stc=1&d=1513819438
BmacIL
Enginerd
Naperville, IL
machsmith
somewhere along the river
Jim
Honda Minis
The injectors are part of the head, it could still utilize the same block.
your a wealth of info 65T, thank you.
Not a question for you directly, but for all. What are the chances this car could come standard with a roll cage?
Stage_3
MA
2019 Roush Stage 3
Wow, if that is true, then this car could have some serious HP and TQ.
Blocks are pretty stout till a certain amount of power, obviously, but it's the cylinder walls that are more prone to damage when dealing with high HP and TQ. Anyone know if there is any truth to this? (Not talking internals here, just the actual block itself and cylinder walls.)
