Here you go guys. Here's the step by step with the IDS tool, laptop, Windows 7. Note that I need a bit more time to put the text with the 30 screen images:
1. Click start new session.
2. Click “all other”.
3. Click check mark to proceed.
4. Enter VIN Number.
5. Select NO.
6. Select new unique identifier.
7. Enter Tear Tag or Part Number from PCM.
8. Select vehicle (Mustang).
9. Vehicle specification, select YES.
10. Click check mark (no need to enter RO or odometer) to proceed.
11. Select tool box icon (red/gray).
12. Select module programming.
13. Select PCM.
14. Click check mark to proceed.
15. Enter VIN Number.
16. Select YES for as built data select.
17. Select CONNECTED for internet connection.
18. Select green check mark to look on network for file.
19. Select green check mark to look on the internet for the file (may vary with IDS level).
20. Click check mark to proceed (states ignition off).
21. Click check mark to proceed (states for new PCM installed).
22. Click check mark to proceed (states to turn ignition on).
23. Click check mark to proceed (states battery voltage must be correct and all accessories off).
24. Click CONFIRM to proceed pass warning about multiple bar graphs during flashing.
25. Click check mark to proceed (states to turn ignition on).
26. Erasing ECU begins.
27. PCM programming begins.
28. Click check mark to proceed (states to turn ignition on).
29. Click check mark to proceed (states calibration has been loaded).
30. Click check mark to proceed (states to get a new label for PCM).
31. Click check mark to proceed (states module is not in vehicle). Note this is only if module is on bench vs vehicle.
32. Exit program.
This was done on the bench (not in vehicle) and we did not turn key on/off. But if in the vehicle, follow the on screen commands.
5. Select NO.
13. Select PCM.
32. Exit program.
