Roush base tune to Lund.
sonic
NY
Prius
With the factory tune back in anything else needs to be done with Lund and make sure he has the proper strategy code.. not sure if loading as built data will change that or not
sonic
NY
Prius
Thank you for helping more than 1 person with this and it was not even your setup that was on the car with! that goes a long way in my book!:cheers:
Here you go guys. Here's the step by step with the IDS tool, laptop, Windows 7. Note that I need a bit more time to put the text with the 30 screen images:
1. Click start new session.
2. Click “all other”.
3. Click check mark to proceed.
4. Enter VIN Number.
5. Select NO.
6. Select new unique identifier.
7. Enter Tear Tag or Part Number from PCM.
8. Select vehicle (Mustang).
9. Vehicle specification, select YES.
10. Click check mark (no need to enter RO or odometer) to proceed.
11. Select tool box icon (red/gray).
12. Select module programming.
13. Select PCM.
14. Click check mark to proceed.
15. Enter VIN Number.
16. Select YES for as built data select.
17. Select CONNECTED for internet connection.
18. Select green check mark to look on network for file.
19. Select green check mark to look on the internet for the file (may vary with IDS level).
20. Click check mark to proceed (states ignition off).
21. Click check mark to proceed (states for new PCM installed).
22. Click check mark to proceed (states to turn ignition on).
23. Click check mark to proceed (states battery voltage must be correct and all accessories off).
24. Click CONFIRM to proceed pass warning about multiple bar graphs during flashing.
25. Click check mark to proceed (states to turn ignition on).
26. Erasing ECU begins.
27. PCM programming begins.
28. Click check mark to proceed (states to turn ignition on).
29. Click check mark to proceed (states calibration has been loaded).
30. Click check mark to proceed (states to get a new label for PCM).
31. Click check mark to proceed (states module is not in vehicle). Note this is only if module is on bench vs vehicle.
32. Exit program.
This was done on the bench (not in vehicle) and we did not turn key on/off. But if in the vehicle, follow the on screen commands.
boosted4life
boosted4life
Fort Worth, Texas
2015 mustang gt
It used as built through the network. I sent teambeefcakes a email hopefully he will get back with me soon because now I'm stuck with a car that doesn't run.
boosted4life
boosted4life
Fort Worth, Texas
2015 mustang gt
Okay finally I got the tune to download. I had to install the sct software on my work computer it wouldn't work with wifi for some reason. The tune is now installing! What a nightmare. I do want to think whipple, teambeefcakes, and sonic with all the help and extremely fast communication. I wouldn't have been able to get any further without your help.
cbear50
dfw
2015 mustang 5.0
That's great news I can't wait to here your thoughts on the new tune. I have always read the roush tune was pretty conservative I'm hoping for much improved performance. If the offer still stands I will have to come out to ft worth now that you got it sorted.
boosted4life
boosted4life
Fort Worth, Texas
2015 mustang gt
Just let me know. I got the id1000 injectors installed and so far it's running pretty well. Haven't got in boost yet, just about to start logging.
Stage_3
MA
2019 Roush Stage 3
So awesome that you finally got it.
Good news. :thumbsup:
dwaleke
Jeep
Keep us posted on the difference between the tunes.
Are you going with a smaller pulley as well?
beefcake
Bethel
2018 Ford Mustang
cody, just get hooked up with the right guy at one of these dealerships, and you'll be ready to rock the tune!
boosted4life
boosted4life
Fort Worth, Texas
2015 mustang gt
Ill be adding a 73mm pulley from the 85mm one i have now. ill let you all know how it goes.
boosted4life
boosted4life
Fort Worth, Texas
2015 mustang gt
So figured I'd give everyone a review if they wanted to know. Now I'm not quite through with revisions yet but very close. I just did a wot pull from around 30-130 and holy F**k it feels like i gained another 100 HP. It's very hard to get traction now even with traction control on. Before anything after 3rd I could grip, Also my rev limiter is set at around 7500 but I shift at 7rpm and man does it pull non stop. It's crazy how just a tune made it feel. Well worth the money so far!
cbear50
dfw
2015 mustang 5.0
Yes I'm going to hook up with boosted4life here shortly he is at a local ford dealer. Can't wait
