RLCA Help: Spherical Bearing vs. Poly Bushing
RLCA: Poly Bushing or Spherical Bearing?
  • Total voters
Dave TBG
Patiently waiting...
New Jersey
'19 EB 201A, '86 Porsche 944
Step 1: Write in complete sentences and coherent thoughts
Step 2: see Step 1
Spell check wouldn't hurt, either. There may be some valid information in there somewhere, but finding it isn't easy.
fatbillybob
SoCal
'19 GT pp1 A10 Orange
im keeping it simple since nobody can follow an explanation linger tgan 2 sentences..
BY YOUR IWN ADMISSIONS.
Simple for you too since you got tens of thousands of hours experience.
I'll repost...."Post up what your design would be for the RLCA for those bushings in delrin. I really need a class legal solution."
TeeLew
So Cal
Tim
For the record, has anyone ever used a suspension bushing, regardless of material, with the bush riding directly on the bolt? If so, that's wrong, it should have a crush sleeve to pivot on & take the clamping load of the mount.
No commercial products operate without a crush sleeve, so all you people out there casting your own bushings need to take note & start using them.
Brian@BMVK
Illinois
2015 GT - Sold
Taking the clamp load and shear/twist loads simultaneously wouldn't be good on the bushing material. With the greased slip fit (like the Superpro design), the crush tube can remain stationary and the bushing be able to rotate around it.
TeeLew
So Cal
Tim
I'm putting the SuperPro bushing in short term & waiting for the other manufactured solution for the long term answer. That looks like it will happen, but it will take a while before we see it. The SuperPro bushings are $112. Even if only 50-75% as effective as a spherical, it's still a lot better than stock & the cost isn't absurd. I understand you don't like poly bushings in a philosophical sense, but sometimes you just have to piss with the dick you've got. They're going to run the race, regardless.
TeeLew
So Cal
Tim
Ya, exactly. I don't know of any aftermarket bushings which operate differently. I think this was one of the things 308 was rattling on about, so I was trying translate his (admittedly correct) PSA into English.
fatbillybob
SoCal
Agreed...but even working on a lift I'm too lazy to do the job twice. I'd really like the other solution we talked about. I hope it pans out...soon!
My post is really a challenge to the big swinging dack to put his money where his mouth is. I'm sure it will be crickets. This sight has a thread ignore feature but no forum member ignore feature LOL! Moderators need to add that feature unless I missed it.
fatbillybob
SoCal
Yes and the primary reason I don't like the poly. Delrin is high durometer and sort of self lubricating yet surprisingly long life. There is less stichon if a delrin tube is rotating around the crush tube than poly. An off-axis bind just puts in more stichon. Delrin won't yield like poly for the off-axis so a compromise...
TeeLew
So Cal
Tim
Sometimes I have an overactive sense of competition, and I kind of want to feel the differences between A, B & C.
TeeLew
So Cal
Tim
Could be, if they actually look more like this. Seems it's the Aussie companies that pay enough attention to what's really going on in a compliant bushing to sneak in some compliance.
Norm
For whatever reason, the SuperPro RLCA bushings I received do not have this undercut. They have a longer taper on each side, but it's not as complex of a shape as this. I was a little surprised when I pulled it out of the packet.
At this point, it is what it is & this is not the final answer. I'll end up with a couple data points to figure out what works the best.
fatbillybob
SoCal
I have a 10 ton press an hour from you. Arms are al iirc so at 500f loose strength so must be careful witj heat. . Maybe be cut them hack saw then dremel when close.
SAY WHAT
Tim
2016 mustang Gt
My set also did not have that cut, if you look at the pictures I posted on the 1st page. I think its just the way the picture was taken that gives you illusion there is a cut.
fatbillybob
SoCal
without the cut is probably stiffer. TEE put the control arm through the +/-2" shock travel and let us know how much off axis bind there really is over that approximate 15 degree rotation.
TeeLew
So Cal
Tim
Great idea. I'll absolutely do that.
TeeLew
So Cal
Tim
OK, so I've got all the corners back on my car with the polyurethane bushings. I haven't gotten it on the ground, yet, so no driving. While I was putting it back together, I made a video about the how the suspension moves with the bushings in. It's pretty smooth. You can feel the drag of the bushing grease, but their isn't any outrageous bind or stiction. It's just feels like you're moving it through syrup.
Anyway, here's the vid.
