emdavis197
- Jul 28, 2019
- Mooresville, NC
- Eric
- 2019 Mustang GT 5.0 *Velocity Blue* (The fastest color)
NASCAR engines actually run fine after each race. Many are handed down / sold to smaller race teams and run without rebuild. That being said, NASCAR engines are putting out over 750 HP with roughly 350 cubic inches (naturally aspirated) so they are built for about 1,000 miles of extreme constant redline usage before needing rebuilding. Ford warranties the Coyote for 60,000 miles with a 7,500 RPM redline and roughly 450 HP (depending on generation). You are wise to not be bouncing off the limiter in every gear all the time, I agree. But shifting at 3,000 rpm isn't doing you any good either. Enjoy the sweet spot between 4,500 and 7,000 rpm frequently, keep up on your maintenance, and you won't have any issues.Formula one engines and Nascar engines rev high and the drivers rev them like crazy therefore they need to be rebuilt after each race. Eventually if we keep reving out our coyote it will cause more heat and premature piston wear. Also you can wear out internal parts like timing chains and also engine accessories like waterpumps.
