Replacement Rotors? Has anyone tried Dynamic Friction?
galaxy
St Louis
'17 GT350
The term 'get what you pay for' was the first thing that popped into my mind. And @Tomeck is right. Didn’t notice that the first time. If the photo is accurate, that’s a hard pass. And at that price point, no way it’s a two piece. I get smart budget decisions, but you drive a 350 man, do it right!
JAJ
Vancouver BC
2016 GT350 Track Pack
This is what they actually are:
https://www.dynamicfriction.com/det...brake-rotors/MTQwNDg0LTEwMy0xLTYyMC01NDA4MUQ=
About 4 pounds heavier than the OEM rotor, solid cast iron rather than two-piece floating. Basically the kind of rotor that OEM's like Ford use on "regular" cars like the base Mustang.
Nothing wrong with them, they'll look ok, but they're not a good choice for anything that involves repetitive high-G braking. The factory GT350 brakes, with the two-piece design not only avoids disk distortion at high loads, it also keeps heat out of the wheel bearings.
There is a half-way alternative to the OEM Ford brake rotors - SHW FFL43125/26 rotors. They're made by SHW, the OEM supplier to Ford for the GT350 brake rotors. It's basically the same rotor with a different looking hat. Cheaper than OEM, better than one-piece cast iron.
https://carrollshelbyracing.com/shw...-front-cross-drilled-lw-brake-rotor-ffl43125/
WItoTX
Houston
Kyle
'17 GT350
Stock 350 rotors aren't real 2 piece rotors anyways in that you can't just replace the ring.
Personally for spirited driving only, I would give them a shot. You're only out 300 if they suck.
And not a chance stock are $1300. True 2 piece girodiscs are $1300. I'd go the girodiscs route if it were my money.
