Released: CR series comp cams
Derek@Lethal
Wellington, FL
Derek
2012 Mustang GT 300A w/ Brembo's
$2400.00 for 20ish hp? Ouch.
Well, the cams are not even $1400, and the harder you push the motor the more power difference you'll see. The stock cams will die at 63-6400 rpm where the stage 3's will take you up to and over 7k. You're extending the usable power range while picking up peak power.
daltron
Rowing All Day
California
Jonathan
2016 GT PP
@Derek@Lethal, I see the stage 3 N/A says 2-7.5K RPM.
Two questions:
One, with just the cams does that mean we can safely rev the motor to 7.5K?
Two, when it says it starts with 2K RPM, does this mean DD street driving is compromised?
Thanks!
Derek@Lethal
Wellington, FL
Derek
Two questions:
Thanks!
1) If you have the induction/exhaust/fuel to support that RPM, yes, it's safe.
2) That means the gains will be more pronounced above 2k. Any time you ad larger cams, cylinder heads, etc... more breathing, it's not uncommon for low end to suffer at least a little bit but what you gain from mid range and above will outweigh anything missing down low.
beefcake
Bethel
2018 Ford Mustang
if your in there doing cams, it wouldn't be a bad idea to do the oil pump gears as well. we ususally do them at the same time,
Blacksheep
Nj
Mustang
Do you really have to do a longtube hwadrs with cam? Or can you get away with resonator delete?
Evolvd
Instigator
Northwest Florida
Brian
2021 Shelby GT500
Honestly for the cost of the cams plus labor you'd be wasting your time if your intake and exhaust wern't as free flowing as you can get them. Spend your money on headers and a tune, you'll pick up plenty of gains with that
beefcake
Bethel
2018 Ford Mustang
Just depends on you're goals.
For a max effort build you would want too
sicks550
Gabe
2015 Mustang GT PP
Any vendors have their hands on any sets yet?
kallo07
Aurora,IL
2015 Mustang GT Premium
How do the stock cams die at that rpm range? When the stock 2015 cams are almost identical to the Ford racing cams, except the exhaust cams, sock it is 263 duration and 13mm lift vs 290 duration and 13mm lift.
Grimace427
NoVA
2011 Mustang 5.0
Generally speaking the cam duration is more important than the lift. Back in the '11-14 Coyotes you could install a 'Mini-CJ' exhaust cam which kept the 11mm lift from stock but increased duration to 290 degrees and it made for substantial gains especially at higher RPM's.
kallo07
Aurora,IL
Seems due to meeting emission regulations ford did not use the exhaust cam. To have a true Ford Racing CJ setup all we need is the CJ exhaust cams.
1320'
Medford,Oregon
2011 Avenger...sadly
And the CJ intake manifold to take advantage of the cams breathing ability, and the CJ intake tube and filter to feed the intake, and the CJ throttle body to help regulate the massive amounts of air flowing into the engine, and a tune to make them all play well together.
In reality the current 5.0 is only about 25% Cobra Jet. It's more like 50% Roadrunner, 25% Cobra Jet and 25% previous Coyote.
kallo07
Aurora,IL
Very true I do agree with you. Gladly I've taken the steps to have the CJ intake setup and tuned, now just need the exhaust cams. I do feel the current tuners are holding back on the motors. As their is more control on these new gen coyote motors and better factory parts
