rearview mirror question
BimmerDriver
RDU, NC
Michael
Dark Horse w/3 pedals, BMW
My rearview mirror auto dimming feature doesn't work. This morning I was looking for a switch (some cars (GM?) have a switch to turn it off) and knocked the plug in and it started working, briefly. I seated the plug in all the way, and it stopped again. So, now the plug is firmly seated, and it's not working (again) and I wish I knew what I did the first time, LOL.
Any suggestions? Is there a switch?
Bikeman315
Myrtle Beach, SC
Ira
There is no switch. Could be a bad connector/connection and/or a bad sensor. If still under warranty, bring it to the dealer.
Elp_jc
None
Cheapo Ford didn't put a switch for the dimming feature, and neither for the map lights when doors open. At any rate, how are you testing the mirror??? There might be a delay built in. And also it doesn't work in reverse, so you know. And how about the door mirrors? It's super rare that those things fail, but it's always possible. Good luck.
ORRadtech
Atlanta, Georgia
No switch.
If bumping it caused it to work and seating it firmly stopped it working then the place to start trouble shooting is the connection and associated wiring.
If it were mine I'd start wiggling wires in the plug harness. From there I'd unplug and examine the plug and socket in the mirror looking for bent/loose or misaligned pins.
Most likely the worst thing about finding and fixing the problem will be the awkward working position.
BimmerDriver
BimmerDriver
RDU, NC
Michael
Take a picture of the connector pins
Nothing to see, they're fine.
Huh. Mirrors. Didn't think about them.
Thanks for the ideas guys. Pins all look good. I'll mess with it more when it gets darker...
Elp_jc
None
You know what, I was confusing this car with one of my others. Just checked the window sticker of my Bullitt, and it only says 'auto-dimming rearview mirror', so never mind, brother. Sorry for the bad information. But yes, checked it at night with a flashlight from behind, and it should dim. Good luck.
BimmerDriver
BimmerDriver
RDU, NC
Michael
Well, I unplugged the cable and plugged it back in. Using the DGWF* testing method, it seems to be working now.
Thanks all for the suggestions, comments and encouragement!
* - DGWF = Dark Garage With Flashlight
Bit_the_Bullitt
Ohio, US
Richard
2019 Bullitt
Sorry to revive old thread. I got one in 2019 Bullitt (I believe the ones in GTs are different and more modern looking). Was there anything specific, or really just plugging in and out?
I've noticed on my morning commute today that I was getting straight up almost blinded in the rearview...
BimmerDriver
BimmerDriver
RDU, NC
Michael
That's all. I don't know if it was loose or just needed a smack.
GaleGT
Hinesville, GA
Gale
2016 Mustang
No switch.
That's what my uncle noticed on the wiring of his rearview. I'll take a closer look this weekend after we installed the shocked from 4Wheelonline onto his Jeep. Too bad it's out of warranty.
Bit_the_Bullitt
Ohio, US
Richard
2019 Bullitt
I have a dash cam (dual, front and back) installed near the wiring, so there's a power in and data out (to the back cam), so it's tight as far as the wires go. I ran it very near the rearview, so I may have inadvertently moved the wiring, would explain the intermittency of it working and not.
Bit_the_Bullitt
Ohio, US
Richard
2019 Bullitt
I've noticed today during my morning drive that the mirror cycles off and on with a car behind me, I think my sensor must be bad. Wiring seems okay. Will test with multimeter today.
Does anyone know where I can find how to test this, i.e. the pinouts?
