Rear Wheel bearings going out fast?
16s550
Bay area
2016 GT M6 performance pack, whipple charged
Is there anything one can do to not have the rear wheel bearings go out so fast? My last set went out in less than 6 months. Car is lowered on 20s. G force axles, m6, whipple. Supporting suspension mods.
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Daily driver, track car? Are you launching on a prepped surface constantly?
Eyesac
Reno NV
Isaac
2020 Mustang GT PP
I've been through x3, after the last one I haven't had to do one in at least 2 years. I would try new axle nuts, red loctite and correct torque on install (pretty hard to get to correct torque).
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Use Ford OEM hubs, use the thrust washers and the latest generation of axle nuts. Torque them down really really hard. They should hold up.
16s550
16s550
Bay area
Daily driver, weekend warrior. Made 785 to wheels and over 6xx torque. I was on a drag radial. Nitto, but now on nitto g2. No traction down low.
16s550
16s550
Bay area
Ive been through originals and two sets of ford racing bearings that come with arp extended studs.
Happen to have a link for the jam nuts? Please
16s550
16s550
Bay area
Ive always used the axle nuts that come new with kit. First set i installed, 2nd had a shop install. Its so annoying how wavy car feels on highway. Need to fix again asap
kz
West Chester, OH
Mustangs & F150
NightmareMoon
If its wavey (BTDT), thats not even safe dude, go get em fixed!
16s550
16s550
Bay area
Will do. Going to order them. Thank you
FUN2RIDEFAST
Ofallon, Missouri
2017 Mustang GT Premium/PP
I've got that going on right now. Left rear but I'll change both sides. Just changed left side speed sensor. What lights did you get? Mine, steering assist, abs, traction control, power steering not working. Same as with the speed sensor. I'm also running Gforce Outlaw axles. What a pain in the ass.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I was told by one of the vendors who also tracks to use BCA hub bearings. So far they are holding up.
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
BCA just buys the NSK (OEM Supplier) so all same hubs as OEM without the drastic price swings.
How Low? The Mustang that was in the paddock next to us destroyed a brand new axle in 20 minutes last week at Indy in Mustang challenge. Ride height is critical on S550 rear suspension geometry, too low introduces weird weird angles and makes the axle overload the rear bearing, and destroys stuff. Use the torque turn method with a new nut. 98ft/lbs + 45 degrees. I believe the G-Force axle uses a different nut, so go by what they recommend and if that is the case our jam nut will not work.
