Rear lower control arm removal
Tnxn
All over
2014 ford mustang
  • Thread starter
  • Banned
  • #1
Hi All,
I am trying to remove the rear lower control arm. Found a great how to with pics, have the arm totally released from the knuckle, subframe etc. Just cannot get it out as it’s hung up on part of a subframe on top, and on bottom don’t see how to get the magneride through. The write up is for an s550 but obviously not a gt350, as for example the shock mounts are on top so for that example the arm just drops straight down. Ours it mounts on the bottom.
Also any chance anyone can send a shot of the owners manual for the control arm removal?
Thanks!
NGOT8R
Adrian
2019 Bullitt
Hi All,
Thanks!
Please post pics of how far you’ve gotten, so we can see how to help.
NGOT8R
Adrian
2019 Bullitt
Here are some pics that will hopefully give you a better idea on disassembly. Note: After removing my rear shocks and axle nut, I pulled down on the spindle and pushed in on the axle to remove it from the wheel bearing and let the spindle rest on top of a 5 gal. bucket. I also made sure to unbolt the magneride linkage from the control arm. This should allow you to remove the control arm.
DougS550
Fishers, Indiana
Doug
So you removed the lca mount bolts, shock/strut bolts and it still won't come out?
DougS550
Fishers, Indiana
Doug
Mine came out without issue. Those are just the steps that I took to remove them.
I TOOK my LT-RT LCAs out last winter without issue also.
djcodeman
Austin, Tx
2015 GT roush SC
Wanted to chime in, as I'm doing this right now.
I was unable to get the rear lower control arm bushing bolt out... even with an impact swivel and a Milwaukee 1400 ft lb impact gun...
I ended up fully removing my shock, then disconnecting the upper control arm to knuckle... this allowed me to use a 15/16th box wrench to break the bolt free (after double wrenching).
DougS550
Fishers, Indiana
Doug
Hate to hear that. I just had my LCA lowered for new spring install. I use a 1/2" 36" ratchet bar to remove those bolts. And I have found, when removing high torque bolts/ nuts, I cannot use swivel universals, multible extensions for the impact hit is absorbed to much to break them loose. Good luck.
djcodeman
Austin, Tx
2015 GT roush SC
its crazy, even with that bolt broken loose, putting the swivel on it with extensions is still losing too much torque to fully pull it out..... wishing I had a 24mm ratchet wrench now haha
Probably will just remove the half shaft to get better clearance
17MagMetal
San Francisco
Michael
17 Mustang GT, 07 Ford Taurus SE, 95 F250 Xlt
It’s a major PITA. And if DIYing on the floor, retorquing it to the 184ft/lb spec (I think) is insane! Especially if you’ve got rubber in it still and have to clock at ride height.
DougS550
Fishers, Indiana
Doug
Hi All,
Thanks!
FYI. Make sure you clock the lca. Good luck
djcodeman
Austin, Tx
2015 GT roush SC
Good luck getting a torque wrench in there lol.. couple ugga duggas with a milwakee m18 on that upgraded bearing and I'm calling it good enough
DougS550
Fishers, Indiana
Doug
I know it was tough. I think I used a crow and extension. But just torque down as hard as you can and call it a day.
